0 Members and 297 Guests are viewing this topic.
conico
I already did it two years ago but without Bridge rectifier.
http://jnaudin.free.fr/kapagen/kapagen33pio.htm
It is a bad measurement method  !A halogen bulb is mostly used as heater part :  but no calori-output measured.
like here "Test # 3" http://jnaudin.free.fr/gegene/indexen.htm
From in-/ output comparison this tests and result means : Also not with a KAPAGEN the halogen bulb can concurr counter f.e. LED with 150/200( Phillips)/300( Cree) lumen/Watt lightning devices !
Tests with KAPAGEN : ( 2505 lumen x 14 lamps) / 1059 W active power ~  33 lumen/ Watt (~ CFL efficiency)
Really not by using this " energy saver" ? Caution, for right physical measurement : CFF
https://patents.google.com/patent/US5130608A/en
          apparent lumen/ Watt ?
CFF and pulsed radiant energy : probably for 99% " free energy devices with bulb demonstration" the fiasko. !
        SELF-DECEPTION
AlienGrey
Quote from: conico on March 19, 2019, 02:40:40 PM
Make a Tesla coil and do this simple device. You will see Over unity.
it's a good experiment if you have some Litz wire but you won't get any over unity.
Sergh
Naudin compared the brightness of a light bulb from kapagen and the brightness of a light bulb switched on ordinary from the power supply network.He did this experiment correctly.
The amount of heat does not matter, since with the same brightness the same amount of heat is obtained.
In this experiment, the Earth itself and the grounding is used as a wire in an electrical circuit. Nothing unusual. Predictable result.
We have an in-/ output device :
A.
partial recuperation ( an- or exergy?)
https://www.patentauction.com/patent.php?nb=13727
C. O. P. /SEER ?
B.
Conversion process optimization
10/01/08 SYRIA Kaffouzi
http://www.keelynet.com/indexoct1008.htm
C. O. P. /SEER ?
C.
e-drive optimation up to 50% less electric power
More savings claim : http://www.freepatentsonline.com/5463914.html
C. O. P. /SEER ?
A + B + C :
C. O. P. /SEER ?
this now as micro-circuit
Without SELF-DECEPTION
But correct FEMM/SPICE virtualization from the thermodynamic gas to electrodynamic gas= plasma circuit
