0 Members and 112 Guests are viewing this topic.
Sergh
There is an unconfirmed myth that when powering the LED with short pulses, it seems physiologically more bright with the same energy consumption.
So I think this is a myth. In addition, the luxmeter does not care about this physiological features of the perception of light impulses.
;D
only for this:
https://en.wikipedia.org/wiki/LED_Incapacitator
Regarding halogen lamps, they are not able to flash fast, for example faster than 1 time per second, because the filament heating is inertial.
Naudin measures energy with a special device, a special electronic wattmeter. It measures the consumption from the electrical network, even before the transformer.
This electronic power meter allows you to measure any form of energy consumed. It has a special chip - energy consumption calculator. I previously posted a link to similar chips.
In some frequency limits, it allows you to count accurately.
Wow,  Sergh, I am impressed !  ::)               ~/= : up to 100/1 ratio
                                " physiologically " : soft facts area , could be or not could be
                                      wristify,EMBR lab : low input / great output " feelings"
                                                          https://embrlabs.com/
                Our body has receptors, but the sensivity is between the several bodies not the same
                                 Genetical,habit ( for an Inuit 0° C is relatvely " spring " ambient) :
                         climate-chamber ( - 100 ° Celsius ) and thermografic camera body controle
                                                      Science wants hard facts !
                                                           Repeat-/ controle-ability
                Not : " it seems that ..... !"( from physics to physio- to psycho to  8) PSI to mental insanity )
        Physiologically :
   a 20 sqm room equipped with 1600 W heater before, later 400 W heater ( Leo Peron)    and finally   40 W heat foils ( Dr. Helmut Reichelt, IR room object heating) to 12 W electric body wear
                                         Also : 100/1 Wattpeak/ Wattdeep ratio
                    Haus-/House-Raum/room or Weltraum/"Space" or body climatization
Your criticism and the KAPAGEN tests result : 34 Lumen/ Watt ~ CFL efficiency , does this result and method satisfy you ?
What was Naudins' target and what is your experimental result target. ?
You can have the world best hardware,
                        but have you also the best " software" and the before/after-vision target/ intention ?
                       Let us beginning with :  halogen lamp lightning efficiency  ( without controller)
https://www.any-lamp.com/lumen-to-watt  in average 10 lumen/ Watt
Definition and relationship :
lux and lumen and Watt and VA and Photon and Phonon and Electron
https://en.m.wikipedia.org/wiki/Heat_transfer_physics
https://www.any-lamp.com/blog/lumen-and-lux/
About " halogen lamps can not flash fast"  http://www.electronics-lab.com/project/pwm-halogen-lamp-dimmer/
              PWM IS FLASHING : energy flashing
And cause the "transformer" in future will become printed :
                              energy transformer: energy prozessor- equivalence
we can transform the termination circuit signals/ pulses per second now to flops per second :
https://en.m.wikipedia.org/wiki/FLOPS
The GFLOPS and TFLOPS price list from 1961 to today and this translating in printed "ambiental energy harvester"KWp/Wp future prices development and as product : KWh power costs decrease
The thin-foil-printer velocity will in future dictate the world energy market price and the consumer access.
About concentrated power densities : http://www.rexresearch.com/yater/yater.htm
Jeg
https://www.youtube.com/watch?v=wq6GZp97uPY
At 1:27 when he connects his loads a hissing sound is present probably due to the high preasure. It doesn't remind me a sound from a spark gap but can't be sure of cource.
conico
Jeg, that the movie  ,of course.
You must give some details of your device.
Do You Know the frequency of your tesla coil?
Did you use a cap in series with  bulbs load?
Did you use a mosfet or 2SC5200 for Kacher?
You must tune the device, first 900 Khz for Tesla coil.
Did you use battery or PSU?
Jeg
Quote from: conico on March 20, 2019, 08:41:42 AM
Hi Conico
Well, my Tesla coil is modulated at 16Khz having a tunable carrier frequency between 600Khz and 1Mhz.
The second PVC pipe (I made two of them) according to its wavelength, I calculate 40Mhz so its quarter is 10Mhz. I need now to calculate the right cap to tune at 16Khz. But I am not sure that this is the way. I looked again Tesla's way and looks quite attempting. Charging a cap and then through a switch to power a load or an output transformer. I will read again what Maxim send to Caprenloz. I think it has already been written somewhere.
About the rest:
2sc5200
PSU at 24V
A battery simulating earth ground.
