0 Members and 134 Guests are viewing this topic.
Void
Hi Sergh, yes, according to some info contained in the Cornell Dubilier "Application Guide,
Aluminum Electrolytic Capacitors", the two electrolytic capacitors are specified as being the same value.
I am not sure what would happen if the two electrolytic capacitors are not the same nominal value.
Here's an excerpt from that document:
"NON-POLAR
If two, same-value, aluminum electrolytic capacitors are
connected in series, back-to-back with the positive terminals
or the negative terminals connected, the resulting single
capacitor is a non-polar capacitor with half the capacitance
to either of the original pair. The two capacitors rectify
the applied voltage and act as if they had been bypassed
by diodes. When voltage is applied, the correct-polarity
capacitor gets the full voltage."
All the best...
Sergh
Hi, Void!
Quote from: Void on March 25, 2019, 09:57:08 PMIf two, same-value, aluminum electrolytic capacitors are
The problem is that the electrolytic capacitors allow a large spreading of parameters. Parameters may change during the work.
At different capacitances and leakage currents, the voltage on one of the capacitors will increase, on the other there will be reverse polarity.
A small non-notched capacitor, as here, can knock the eye out..
https://www.youtube.com/watch?v=rr7bPmGTQUk
AlienGrey
No Sergh, absolutely. I've seen guys working over devices with caps that have exploded, flying charged lethal aluminum roll flying through the air, what would have happened without the earth leakage circuit breaker?
it's not a new get out invention for corner cutting, get the right component for the job.
AlienGrey
T1000 wrote this, quite right too!
Quote.
Offline T-1000
Hero Member
View Profile  Personal Message (Offline)
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #10529 on: 29 September 2015, 16:36:13 »
Feller's
Messing with each other won't do any good. In the end, it does not matter which electronics you use for creating the same signals which follow the same conditions for resonance and managing sharp pulses on top of the sine wave. As long as you are able to follow what was said and shown by multiple people with creating the same conditions it is all OK.
The background EE/RF knowledge required can be learned if you really struggling with bits in it and that only takes time for understanding how two waves interact with each other and how signals need to mix and match in grenade coil..
Cheers!
AlienGrey
Quote from: Hoppy on September 25, 2015, 07:43:01 AM
Thanks. I understand from previous posts that the natural frequency of the grenade coil needs to be found with the earth wire attached and inductor coil (Tesla Bifilar) wound over the grenade coil. If this is the case where should the frequency generator be attached and should the inductor be loaded and if so with what, when the frequency measurement is taken? I believe Nick is working to the TOPruslan FEG 2014 schematic redrawn by Ibrahim@cicek. This shows a(((((  375.75 )))))) metre grenade coil winding length and an 18.75 metre main ground wire for 34.15KHz / 1.736MHz working.
thats almost 400 Meters  ;D ;D ;D ;D where is he putting it all ?
But note the circuit underneath your post I mean don't any of you guys notice all the mistakes in it ?
and Void and Nick tell me i a know nothing? quick hand me a banana  ;D ;D
