0 Members and 347 Guests are viewing this topic.
GeoFusion
Hi All,
The my recording according to the schematic
https://www.youtube.com/watch?v=s9YqkzlKulE
what I can say is that I have the manifestation happening on different spot which was not ment.
Anything can happen and should be prepped for anything.
As I disconnect the ferrite piece from antenna you see clearly that It aint producing much.
Kacher here is doing it's job, and the synchronization connection area is very important
and how you connect ground and emitter side of Kacher.
Should be repeated this to see if it can be done by anyone els but one word, this is very unstable.
you will get maybe 60V ac out and constant at hat point of caps at 3T used for load
AlienGrey
Hi, Geo, I can see the grenade waveform locking in time with the Katcher but how do you alter the phase position with this circuit?
bearing in mind I haven't tried this. Re 'colors' phase shift waveform. Had a look for the link but Color was flitting around with Wesley's channel and he has wiped a lot of none relevant stuff to his project.
Jeg
Geo
Always nice watching your vids. Looks like you are there. Have you tried to self loop it? Don't you think that the inseries diode with your grenade is needed?
AG
By connecting his katcher at that point, means that Katcher driver fires between push pull pulses, by the inductive transient of "mediator". In other words when current is at its maximum point. So it already has the right shift. No fancy circuits at all., straight to the point.
AlienGrey
Quote from: Jeg on March 31, 2019, 04:49:49 AM
Geo
AG
Not really it depends on the phase angle of the windings and the way the coils are connected up I would like to see
a scope shot of the voltage and current being out of phase by the correct angle as he was reporting only 60 volts at the output
and according to his videos, he is no longer using that particular circuit presumably it has a poor return.  Most probably a loss.
AlienGrey
I was looking through the database  found a PCB for the same old circuit 74HC132 driving the 8pin Fet driver
I wonder how many have  made it, I wonder how many got it to work, Hoppy could have a field day with half this stuff
