0 Members and 188 Guests are viewing this topic.
NickZ
Quote from: GeoFusion on March 30, 2019, 08:22:30 PM
Hi All,
The my recording according to the schematic
https://www.youtube.com/watch?v=s9YqkzlKulE
what I can say is that I have the manifestation happening on different spot which was not ment.
Anything can happen and should be prepped for anything.
As I disconnect the ferrite piece from antenna you see clearly that It aint producing much.
Kacher here is doing it's job, and the synchronization connection area is very important
and how you connect ground and emitter side of Kacher.
Should be repeated this to see if it can be done by anyone els but one word, this is very unstable.
you will get maybe 60V ac out and constant at hat point of caps at 3T used for load
   Geo: Your set up was replicated by someone,  me.
   Here is my video version of that particular way of connecting things up.     I wonder why we can't get higher output voltages, as I also was getting about 60v or so, at the output. Which should be at least 120v, or higher. I am using 120v bulbs. But, taking the output from the 3t coils circuit at the 0.47uf capacitor, offers a lower total output at the bulbs, with more amps, but with less voltage.
   We need to compare notes in the future, to see if we can get to the bottom of this.   https://youtu.be/NKJpPyMBxwI
   Jeg: At minute 1:38 you can see the "line filter" that Geo was using. It's a toroid core with about ten and ten windings.
   I don't use a line filter. As I can barely fire up the 24v feed back PS. Without enough feed back voltage to this PS, the green indicator bulb will not light, or will light by dimly flickering.
   Do you have your device set up at this time? Have you tried to make the feed back path?
   It's important to install this feed back loop circuit, as it will change things, and the device will need some retuning.    https://youtu.be/cYE1Ne0t6pA
Jeg
Nick copy it.
I should tell you that you make a great work and your dedication on this is remarkable. I have everything on my bench, they just need a some short of re-arrangement. I just wait for a bit to understand what is all about with Maxim/Aliev type devices. I still believe in them.  If anything new i'll share it.
justawatt
Hi I need small help translate this video about andrean Ruslan
Circuit
This was taken down from his youtube channel
I think he explains how to tune the carande coil
Stivep please help and please share this in your channel
YouTube deletes my YouTube channel every time I upload
Some important video so I will delete this video after 1 week
https://youtu.be/Yadc8BDT6uY
NickZ
   Jeg:   I just made this short little video to show how Dr. Stiffler's "diode loop" works with the Kacher circuit.
But, I was interrupted at the end of the video, and had to stop the video before I was finished. Any way, the led bulb lights really well, off of the Kacher signal when using the diode loop. And even better yet, at the end of the grenade/rectifier/caps output. That was where I was interrupted. And so I'll make another video at night showing some other bulbs, like a mercury vapor 170w bulb lighting off of the Kacher, and more stuff, later.   I ordered a new voltage regulator which blew on my induction circuit, and I'm waiting for that part to be delivered. So, once I get it, I'll continue with the Grenade/Kacher tests.
   https://youtu.be/-wblGUkeV6w
Jeg
Hi Nick
I have never experimented with Stiffler's circuits. Is that a kind of receiver? If ypu light 100 of them will they draw more power from kacher?
Thanks for the vid  ;)
Justawatt
Thanks for sharing. He uses a push push device instead of push pull!!! Color has showed this yoke core again but i didn't know it is that guy.
Interesting.
