0 Members and 522 Guests are viewing this topic.
NickZ
  Jeg: Yes, there is a  limit as they share the kacher's output. But, the bulb is also being fed by the diode loop, as they are switching diodes and become additive in voltage.
Jeg
Quote from: NickZ on March 31, 2019, 02:55:07 PM
Yes. Their forward voltage is additive.
Look at the following image. It is acula's. Notice where he connects the earth ground. It corresponds to the middle of grenade. Between 2nd and 3rd layer. There at which the coil direction changes. I think it worth for someone to test it.
Also notice how he keeps separate earth and system's ground. He connects a pot of 1k in between. That means that there is a difference in potential level between grounds, and current can flow between them. It is a kill to shortcut the two different energy references if we like an ''open'' system.
NickZ
   Jeg:   That diagram is not of the Akula second device but was somebody's version of his first device, instead. And is not right.   The ground connection vary with different circuits. Try ďifferent points. Best to go witb the 37 or 40 meter welding cable for the Earth ground line. But if the circuit is out of tune, the earth ground makes no difference.So you need to tune the frequency match, along with the proper ground line in place.
AlienGrey
Quote from: NickZ on March 31, 2019, 03:38:54 PM
   Jeg:   That diagram is not of the Akula second device but was somebody's version of his first device, instead. And is not right.   The ground connection varies with different circuits. Try ďifferent points. Best to go with the 37 or 40-meter welding cable for the Earth ground line. But if the circuit is out of tune, the earth ground makes no difference. So you need to tune the frequency match, along with the proper ground line in place.
Does your Katcher HV winding go to your 2SC5200 base because I would be interested to know how you connect your Earth to the lower end of the winding?
Also a nice light display from your Katcher could I also ask how much current your device draws from the 24volt line too?
Sergh
We all have an idea of ​​what the Tesla energy transmitter was. But nowhere is there a detailed description of the receiver.
What is the principle of the receiver ...
Glow in the night sky over the Atlantic ..I think that Tesla's wireless transmission was not at all what many people represent. The transmitter at a certain frequency (low) pulled, precipitated a charge from the atmosphere, the ionosphere. "Tractor beam" The charge went down at a certain distance, not on the transmitter. The distance was determined based on the wavelength.
https://pdfs.semanticscholar.org/c4af/433c5d90b95eb962c3dcb7d3c09c64a16afe.pdf
It is necessary to calculate. Probably the exact frequency can be determined by the map. Who can tell where Tesla lit 200 light bulbs 25 miles away, on Google Maps etc? Where was the transmitter, and where are the receivers? In determining the frequency, one can understand the height of interaction with the atmosphere. Close to the HAARP topic. It is unlikely that it is related to Kapanadze. But if he claim that he uses Tesla technology, then it is necessary to understand this. The theme of ionization of the atmosphere intersects with the Schumann resonance, in some way.
QuoteTesla thought this would allow alternating current to be received with a similar capacitive antenna tuned to resonance with it at any point on Earth with very little power loss. His observations also led him to believe a high voltage used in a coil at an elevation of a few hundred feet would "break the air stratum down", eliminating the need for miles of cable hanging on balloons to create his atmospheric return circuit. Tesla would go on the next year to propose a "World Wireless System" that was to broadcast both information and power worldwide.
https://en.wikipedia.org/wiki/Wireless_power_transfer
QuoteI was rewarded in these efforts with quick success largely because of the efficient method I adopted which consisted in deriving from a great mass of air, ionized by the disturbance, a current, storing its energy in a condenser and discharging the same through an indicating device.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg532869/#msg532869
To get Tesla's free energy, a power plant is needed:
QuoteNot Much Power Yet
Dr. Tesla stated that the amount of power he was able to develop in the device was insignificant. I asked him if its power output was of the same magnitude as that of Crookes' radiometer, the device with four vanes in a glass tube that are rotated by sunlight, and which is often seen in jewelers' windows. He stated that the power output was many thousand times that of a Crookes' radiometer.
"The attractive features of the Cosmic rays is their constancy. They shower down on us throughout the whole 24 hours, and if a plant is developed to use their power it will not require devices for storing energy as would be necessary with devices using wind, tide or sunlight."
http://www.tfcbooks.com/tesla/1932-07-10.htm
