0 Members and 408 Guests are viewing this topic.
Jeg
Quote from: NickZ on April 05, 2019, 11:42:33 PM
   Jeg:
   I continued on with the Kacher/Grenade diode loop tests, and have found a way to light the AC led bulb to what looks like very use able brightness levels. Possibly full brightness, or close to it. Too bright to look at, in any case.    I would think that several of these AC led bulbs along with the diode loop combinations can be run off of a Kacher circuit, and be able obtain some nice output. It's not free energy, but can provide some good light in times of need.  Also, it may be somewhat like what you were working on, with the Roma self runner circuit.  Any news with that project? How's it coming?
     Here's a little video that I just uploaded: https://youtu.be/DjXW4X0VfSo
    NickZ
Hi Nick.
Nice playing over there. It can give a nice touch during friend-parties! :)
In relation with Roma/Aliev.
Just by using HF, no matter what coils or combinations you make, you will never see something out of the ordinary. I bet that they both use their 12V dc battery in line, instead of Ruslan's AC LF current inductor. So i turned my focus again on Ruslan and right now i am building my arduino synchronising board. Alega's board didn't serve well my needs. With arduino i 'll have a control in every aspect, like the number of the pulses which will drive kacher, their frequency, their duty cycle, and of course control of their phase.
I also made a new grenade starting with 60T on the first layer. At the end it took me 36m of cable. But this time i didn't make it with a one shot of wire. I seperated the two opposite wounded coils having four ends now and giving me the ability to treat them as seperate coils for more combinations. In progress...
conico
 Grenade coil is not in series with 28 turns
Jeg
Conico
Nice catch ;) He feeds his Kacher with this voltage. I have seen it again before. I attach a similar schem. Actually almost the half of the schematics use the 28T part as a supply for the high frequency stage.
AlienGrey
Quote from: Jeg on April 06, 2019, 06:11:15 AM
Conico
Nice catch ;) He feeds his Kacher with this voltage. I have seen it again before. I attach a similar scheme. Actually, almost half of the schematics use the 28T part as a supply for the high-frequency stage.
Jeg  the above schematic your featuring I'm just playing with the lower part of that circuit i have knocked up
it's really well designed and drives the output Mos-Fet directly (in that circuit) the driver can be used to protect that output device by adding 3 resisters and a semiconductor device far faster than any fuse without drawing amps in fault mode under normal conditions. Should others make it/use it. Notice the Katcher circuit 'F' is locked to the input sync frequency of the input of the SG pulse. It depends on if you want to try diode cap multiplier circuits  8) 8)
One thing that is misleading in that circuit is using the 28turn yoke winding in that circuit. You need that to drive the grenade output winding as it will never work off the 4 turns winding alone. You could add another 28turn separate winding but then you would need to play to get everything right under load and the high voltage of a high enough potential   ;D (too much monkey business for my liking).
conico
No, You will not need to add an other 28 turns. Choose to put your oscilloscope probes one on Grenade coil and one on  inductor (not on Wima Cap) directly on terminals of inductor.  Those two signals must be opposite or 180 deg between them. In my two picture with ''The secret  of toonig the Ruslan's device'' I posted said that: ''the two signal must be opposite''
So, First you must have a cap for resonance on grenade coil terminals (not Grenade coil in series with 28T) just Grenade with cap in parallel. Then sweep the frequency of push-pull and see the signals, will be  in faze and some frequency will be opposite.
Choose the frequency off opposite part of signals.
Then you must go down with the duty cycle of push -pull until you will see The double of frequency on inductor signal.
That it, without 28 turns in series with grenade.
Sorry ,i don't have time to do a little movie with that , may be in may.
