0 Members and 528 Guests are viewing this topic.
justawatt
Quote from: justawatt on March 31, 2019, 01:44:36 PM
Hi I need small help translate this video about andrean Ruslan
Circuit
This was taken down from his youtube channel
I think he explains how to tune the carande coil
Stivep please help and please share this in your channel
YouTube deletes my YouTube channel every time I upload
Some important video so I will delete this video after 1 week
https://youtu.be/Yadc8BDT6uY
Hi Wesley can you check this video can you help to translate this
NickZ
Quote from: Jeg on April 06, 2019, 02:49:57 AM
Hi Nick.
Nice playing over there. It can give a nice touch during friend-parties! :)
In relation with Roma/Aliev.
Just by using HF, no matter what coils or combinations you make, you will never see something out of the ordinary. I bet that they both use their 12V dc battery in line, instead of Ruslan's AC LF current inductor. So i turned my focus again on Ruslan and right now i am building my arduino synchronising board. Alega's board didn't serve well my needs. With arduino i 'll have a control in every aspect, like the number of the pulses which will drive kacher, their frequency, their duty cycle, and of course control of their phase.
I also made a new grenade starting with 60T on the first layer. At the end it took me 36m of cable. But this time i didn't make it with a one shot of wire. I seperated the two opposite wounded coils having four ends now and giving me the ability to treat them as seperate coils for more combinations. In progress...
Yes, well that is what most people would think, concerning the HV being the only source of input, with no LV source, as well. That that approach is not going to work. However, Roma may have a LV source, from the other coils on the circuit. But, if the coils are not EXACTLY the same, the needed sync may not work as he shows. As there is no other way to tune that circuit.
However, it has been done. At least, if what we see it true. Possibly the same thing is true with the Kapanadze earlier self runners.   The fact that no one has made a true replication of either of the above mentioned guys devices, Roma and TK, does not mean much. As no one has made an exact replication, but versions of it, instead.
   I have made and shown in videos of how I took the 28t coil's output, rectified it, and connected it to the Kacher circuit.
But, that in itself did not produce much better results, nor worse, but it can provide a higher input to the Kacher, than the 24v batteries do. But, a higher input is not enough to see better results, if the proper frequency sync is not there.
   With all the arduino's controls, again, if the proper sync from both HV and LV is not right, without using the proper coil sizes, etz...the variable controls on arduino may not make up for it, to the needed degree.
  conico:  I have tried to connect the grenade with the 28 turn coil circuit in various ways, over the years. In series with the inductor, as well as separately. I have not seen much difference, except that the series connection provided a higher output, than when the 3t coil is connected separately.   I've also tried many different caps on the grenade output coil. But, still no cigar. I still think that the proper sync is what is missing.   I will continue reworking my Kacher and grenade circuits sometime next week.
   Good luck with your builds.                                           NickZ
NickZ
Quote from: conico on April 06, 2019, 10:36:34 AM
No, You will not need to add an other 28 turns. Choose to put your oscilloscope probes one on Grenade coil and one on  inductor (not on Wima Cap) directly on terminals of inductor.  Those two signals must be opposite or 180 deg between them. In my two picture with ''The secret  of toonig the Ruslan's device'' I posted said that: ''the two signal must be opposite''
So, First you must have a cap for resonance on grenade coil terminals (not Grenade coil in series with 28T) just Grenade with cap in parallel. Then sweep the frequency of push-pull and see the signals, will be  in faze and some frequency will be opposite.
Choose the frequency off opposite part of signals.
Then you must go down with the duty cycle of push -pull until you will see The double of frequency on inductor signal.
That it, without 28 turns in series with grenade.
Sorry ,i don't have time to do a little movie with that , may be in may.
   Anď what were your results?   My inductor and the grenade output coil are running at the same frequency.
conico
I didn't finish my device yet.  Now i have 500w bulb on load with light at 30-35% not on wima caps but on grenade coil. If i will use 200w bulbs on load the light of them can be at 80-85%. I don't have time for experimenting until May
''My inductor and the grenade output coil are running at the same frequency. ''
I'm sure you have your oscilloscope probe on Wima caps but you did't try probe on inductor, in may case was the same. I realise that probe on Wima caps and on inductor are different signals.
Be careful you must have a 100x probe
AlienGrey
Hi, I'm afraid I don't quite understand the 180 phase shift thing (that's half the wave opposing) that means current and voltage
never meat up so no output, the way my mind works.
Have a look at supplied waveform from Ruslan.
