0 Members and 569 Guests are viewing this topic.
T-1000
Quote from: NickZ on May 10, 2019, 12:31:13 PM
   I would like to see a test showing any real power at all, coming from the ground line. As I doubt it. Going to the ground, yes.
   Nor do I see any unipolar pulses, on any of the self running videos.
And those videos never show real power going through ground cable. There are only tips from Kapanadze videos when people used clamp meters (ignore the meter readings) on the ground cable. And to amplify output power the main power source is not the source energy for sure. So.. Make some tests yourself?
NickZ
  T:
   Good points, but I don't need to test to confirm what I don't believe in. But, what I feel is true, instead, such as energy from the ambient.
   We need to find the real source and interaction responsible for any "extra" energy.
   No one that I've seen videos of used unipolar pulses. Although they would probably work better than AC for the HV, if you can find a way to do it. However, are they really needed to obtain FE, to any degree,  or not?
AlienGrey
If the device is not sucking electrons from the ground then it sucks from the environment i'm told
T-1000
Here is another place to refresh memory, Fabrice Andre - https://youtu.be/B6hVasVR7AI?t=33
NickZ
Quote from: AlienGrey on May 10, 2019, 12:56:41 PM
If the device is not sucking electrons from the ground then it sucks from the environment of from 'you'. thats why Wesley was feeling sick! Nelson was saying about it and so was Henry Morey !
I have been next to my circuit for many many hours, weeks, and months.  I guess that I must be immune to electrons being sucked from me. Or, any other worries.
   As Wesley nor any one else can not replicate the workings of that simple two SG device. I can't put faith on what can't be replicated by anyone since then, including Wesley. In any case it was not free energy, but needed two SG to partially light a bulb.
  Below is an image of my simple Kacher circuit/grenade running on 18v, partially lighting 600w load. With some interaction from the Kacher. This is still a work in progress. But, I have not seen any of the controllable Kacher circuits (interuptor), or PLL circuits doing any better, as yet. So... what is really needed, or not.
