0 Members and 126 Guests are viewing this topic.
URFA
I want to share something with you. T1000 and Nelson knows well what I want to say is that . I previously wanted to tell on this site but some of you were opposed to what I said. And they wrote again and again that what I said was wrong. But what I said was true. No one has to believe my writing. But maybe it's useful for one of you.
The most important part of free energy is the capacitor. If you charge a capacitor with high voltage and high frequency and rectified with fast bridge diode has no resistance anymore and the cap charges instantly.  Then you got charge inside a cap and making that flow is amps.
If you load push&pulls at 50-60Hz per second and your cap charging circuit is doing 220-300kHz a second you got a lot of charge in the cap bank to pull into amps. I won't tell you exactly how to do this. But I will tell you the right way. The energy stored in a capacitor is a function of the voltage across it and the capacitance. Stepping up the voltage to any desired high value is very easy to do with the use of a high voltage module. Example is a flyback transformer. This means large amount of energy we can be created and stored inside a capacitor from any source of small input voltage and current.  And this energy directly into an inductor after each recharge. When the LC tank circuit is in resonance the entirety of the capacitor energy is transferred to the inductor and stored in its magnetic field. This means the previous electric energy is now to magnetic and thereby yielding desired amperage. You should use for switching mechanism  such as transistor, high voltage power Mosphet,Thrystor..etc. The most important is to match resonant frequency of the LC to guarantee at each cycle the energy gets fully transferred from the electric field of the capacitor C1 to the magnetic field of the inductor L1. Then released by L2 in the form of current out to the load and output capacitor C2.
That's all for now...
Best regards.
NickZ
   Urfa:   Thanks for the information. Can you say where you got the idea for the diagram that you just posted, and have you tested the circuit out yourself.
   Is that supposed to be something that Ruslan built previously and self runs, or not?
   Which device version that Ruslan has shown is a REAL self runner, in your opinion. IF any...
   Sorry for all the questions.                                            NickZ
GeoFusion
Quote from: URFA on May 19, 2019, 07:54:15 PM
Best regards.
Hi Urfa :), it has been a while and Hi all,
Yes that is what we need to focus on.
the discharge creates so much amps after fast charging with DC.
I have blown two diode bridges by doing this and was able to light up 500W very bright.
I did a pause after accident... but will continue.
Cheers.
Jeg
Urfa thanks for sharing your insight. Indeed capacitive reactance drops by frequency increcement as Xc=1/2πFC
While a series LC is oscillating, there might be a "time window" during which we can charge the resonating capacitor through a HV-HF module as you say. This time window is when current inside the LC is zero. Thanks for your refreshing idea. We really need to focus our minds again after the initial shock.  ;)
AlienGrey
Quote from: Jeg on May 20, 2019, 03:29:59 AM
Oh Yeah' Shock horror to quote the late comedian Spike Milligan!  ;D ;D
Anyway URFA'
URFA, thanks for the interesting chat with a really interesting collection of disclosure of facts.
