0 Members and 143 Guests are viewing this topic.
Grumage
Dear All.
Back from testing the latest choke. This one has got 252 turns,(300 target) I ran out of wire!! Of 1.5mm Sq single insulated cable. This was wound in three layers.
I have posted the scope shots of the resonance in freewheel. Now what is interesting is that the frequency stays constant despite the input frequency variance, It comes in and out of this resonant cycle for most of the lower drive portion but comes into phase with the drive after 95 KHz.
The second shot shows an expanded view and you can see there is a lot going on within the ring down.
All tests were done with 75Vac to the FWBR as per schematic see here..........http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg364932/#msg364932
Cheers Grum.
verpies
Quote from: Grumage on July 22, 2013, 05:50:03 PM
The behavior appears to be conventional.  Your ringing does not have the time to decay all the way down to zero and the ringing period seems to be 10.5μs.
Сергей В.
anandml
From Сергей В. post
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/new/#new
Only for Experimenters
Гость УСТАНОВКА 2 kwatts on 220V
http://www.youtube.com/watch?v=gz0IPdPbHvA
Author (not ikako chubinidze) achieved 2kWatt output power with 100watts input.
Use Nanoperm stripes 2cm = about 0.78 inch wide.
Master ТДКС oscillator (HV-TV transformer with built in HV diode(s)) must be very stable and thermally compensated. Any industrial ШИИ (PCM) will be good here. Also you can use master oscillator based on microcontrollers and high speed mosfet drivers. For isolation use GDT gate drive transformers. Optics is too slow here. Schematics can be found on internet.
This circuit need very fine tuning and very sensitive is to pulse-with and Cкважность parameters.
Cкважность is our Russian term and means pulse period-to-pulse duration ratio or relative pulse duration.
S=1/D
D= duty cycle.
Use Aviation aluminium for tube. Diamtere 5 cm - 2inches. Bifilar was wounded in counter-plan. 1/2 half righ direction - other 1/2 left on whole lenght. Output power also depend from distance between Nanoperm windings. Tune it between 1-2.5 mm and keep the distance step constant. Use good Earth grounding. Heavy cooper bars deep in wet soil and check earth conductor with compass !!
Удачи !!
ps: It seems to me there only couple of CE people doing experiments. Other fishing in "troubled waters".
nbxxj
Quote from: anandml on July 23, 2013, 01:56:28 AM
From Сергей В. post
S=1/D
D= duty cycle.
Удачи !!
"Nanoperm" What does it mean ah? Google can not translate!
