0 Members and 1110 Guests are viewing this topic.
soliman
Hi all.
what I want to say here, in relation to akula seting is:
For example: we have two resonant frequencies one is at 14kHz and the other is at 28kz. Approximately we are going to make a walk through the range of frequency from 10khz to 40khz. all right.
We started at 10khz. as we go up to the resonance of the 14khz. You will begin to add the peak voltage, while the peak voltage is 28 kHz. It will be very attenuated.
but it will be in phase with each other.
we continue to be in fracuency, we pass over the resonance and now the resonant 28khz will begin to rise in voltage.
at a certain moment it suddenly changes phase to 180 degrees. At this point, go back slightly, and you will find something very similar to 90 degrees in phase.
I have been able to prove that at this point "Radio Moscow"
It is more censible than it is other frequency ranges.
I could find that there are other resonant frequencies
in or near this range.
soliman
soliman
WhatIsIt
Quote from: AlienGrey on May 29, 2019, 09:01:05 AM
As a matter of interest I think you will be very lucky to get the 'Lamp' circuit to work as it has circuit errors in it.
There is another couple of 3 threads dedicated to that circuit where Enjoykin goes into depth on the device I think if i recall
he says you need 2 SGens and a 2 channel 50mhz scope eo get any where.
Also the Akula Shark device you need C with timed spark gaps they are missing and you don't know how to wind the coils
or how it works, you need to find out where the energy is cumming from before you can capitalize on it then you can tell the rest of us  ;D ;D
AG
I agree with you! I even try to simulate circuit. Waste of time!
In my post I just answered to member Utopia Now my opinion about that output coils. Of course, it is probably very far from real solution.
At that moment it seems to me that it could be attempt of mixing voltage and current at right phase angles and I expressed my opinion.
I don't think this circuit is worth a dime!
But, there is something else which bothers me? Why replicate others?
We are not smart enough to make our own ideas?
The exception for me is Kapanadze. That man really made true thing. When you look his face and behavior in all that countless videos, he does not lie.
He had something and he guards that with his life. He will rather die than tell the truth, which is another mystery to me.
He must be aware that somebody will do the same in time, and he will fall to ground with his face splashed into the dirt.
But he is persistent. Stupid, if you ask me! And he is already old man who will soon end his life journey, taking his "Precious" to his grave.
But, I have to accept that kind of persons are real and exists.
Time will tell!
Good luck and Cheers!
T-1000
Mhm, why suddenly all other ideas are thrown into mix at once...?Can you guys just test 1 thing at a time? ;)
