0 Members and 823 Guests are viewing this topic.
AlienGrey
Quote from: soliman on May 29, 2019, 06:19:39 PM
Hi all.
what I want to say here, in relation to akula seting is:
For example: we have two resonant frequencies one is at 14kHz and the other is at 28kz. Approximately we are going to make a walk through the range of frequency from 10khz to 40khz. all right.
We started at 10khz. as we go up to the resonance of the 14khz. You will begin to add the peak voltage, while the peak voltage is 28 kHz. It will be very attenuated.
but it will be in phase with each other.
we continue to be in fracuency, we pass over the resonance and now the resonant 28khz will begin to rise in voltage.
at a certain moment it suddenly changes phase to 180 degrees. At this point, go back slightly, and you will find something very similar to 90 degrees in phase.
I have been able to prove that at this point "Radio Moscow"
It is more censible than it is other frequency ranges.
I could find that there are other resonant frequencies
in or near this range.
Hi Soliman  could you please say what the waveform is please, where it is that your scope probes are connected to,
and thank you so much for sharing your time with us AG
AlienGrey
Quote from: T-1000 on May 29, 2019, 09:55:40 PM
Hmm, why suddenly all other ideas are thrown into mix at once...?Can you guys just test 1 thing at a time? ;)
Arunus hi, yes indeed I have a grenade setup i need to test out soliman's suggestions I can get a 90 phase shift
and before that i had various resonant points i could set up with capacitors i could move but nothing else.
I also had a look at ?Ismail's 3 videos and noticed a similarity with the IVO Nelson device spooky! it would look as if a
simple Katcher sine wave pulsed might as he suggests might work. But haven't had the time as noticed after visiting Lithuania guy's 'FreeEnergyLT'
site.
My system started saying 'recycling' a system control files ! so had to reformat HD and start again from scratch as couldn't repair system.
Such is life. So be aware.
AG
NickZ
Hi all.
   soliman:  I notice that the voltages are really low. Do you notice a rise in voltage at 19KHz. Do you have caps on the C! and C2, and no other connection to the rectifier or feed back circuit? So you found no rise in voltage at the 15KHz and 30KHz, as Ruslan mentioned? My best frequency is running at 22.6KHz, or so.
   T-1000:  I have made the CT for the ground test. Will be doing that test later today, along with testing the current and frequency points, along with the voltages on the 3t coil circuit, as well.   I am focused on this circuit, and no other circuit or device, for now.
soliman
Quote from: AlienGrey on May 30, 2019, 01:11:06 AM
pic_107_5.png is on 0 degree.
pic_99_1.png in on 90 degree.
pic_93_2.png in on 180 degree.
I am connect on C1 and C2
[font=]Cheers![/font]
Utopia Now
Hallo WhatIsIt
Thanks for the link to the Kapanadze interviews translated by Wesley ( Stivep1 ) http://www.magistrala.cz/freeenergy/2011/01/09/kapanadze-my-comment-known-as-translation-part-1-video-16/
Thanks for the suggestion of "Can you do it without capacitor and inductor with design of coils? That will be automatic resonance of shifting phases of each coil to produce one output phase aligned. (about Kapanadze question style resonance...)"
And I know you suggested "automatic ..  but still I  remebered a video not with automatic but with cap and coil which I found interesting.
It made me think about Fabrice André 1,7 kW unit . In the video he says : "here we see very good the current that arrives on this little apparatus, Voila, that allows us to afterwards adjust very simple on a capa(citor) the resonance from the coil L1 and L2"     https://www.youtube.com/watch?v=KNyqMIe997s#t=157
His little apparatus is a variable inductor  and is in series with the 2 small capa citors.
And interesting Power .. voltage and current 0 degree ..  I still have to read more about "power factor corection and phase shift" . Thank you.
I think you are right WhatIsIt  ..  we can make our own idea, version, schematic, device
Combine all the working principals   and  construct .......
What are the required ingrediënts for a working device ..
The picture is from the video and the other picture is from pdf from Fabrice André where he talks about automatic resonance ( he writes: "you have to find a way that L1 and L2 are at automatic resonance" )
