0 Members and 823 Guests are viewing this topic.
T-1000
Quote from: Utopia Now on May 31, 2019, 04:08:44 AM
The picture is from the video and the other picture is from pdf from Fabrice André where he talks about automatic resonance ( he writes: "you have to find a way that L1 and L2 are at automatic resonance" )
Thanks for translated pic.
Yet again it is talking about charges from Earth ground in resonance coupled as capacitor plate.
Not sure if there was anyone testing that. And it is another reason to see what can be done with Earth cable with making max current going through it.
Cheers!
WhatIsIt
Quote from: T-1000 on May 31, 2019, 05:23:44 AM
If? Just if? , the big coil in Kapanadze device is capacitor (I think it is), can be similar process involved?
That Kapanadze capacitor has probably small value of capacitance, but big surface which can influence the whole coil.
If it is energized with HV pulses, the field of that capacitor can be strong (this is questionable). Question is how much it can influence coil?
And if that capacitor is small capacitance it wont need to much energy to drive it.
I will try to make one, just to see how it behaves and influence coil, and most important how strong that field of capacitor can be at HV.
Probably will fail, but I will try. I am interested in Kapanadze because I believe he is genuine.
Just a thought!
WhatIsIt
Thanks for the suggestion of "Can you do it without capacitor and inductor with design of coils? That will be automatic resonance of shifting phases of each coil to produce one output phase aligned. (about Kapanadze question style resonance...)"
And I know you suggested "automatic ..  but still I  remebered a video not with automatic but with cap and coil which I found interesting.
If you dig into current and voltage phases, reactive power and power factor correction methods you will learn a lot about power and how to manipulate it.
And you will benefit on that.
If you have transformer with primary and secondary different inductances will there be phase shift or some other kind of differences?
If you have auto transformer, can it have that same phase shift? Or it will be different.?
Both can do the same job.
In first case coils are separated. Primary and secondary have to resonate or whatever?.
In second case you have one coil which does not have to resonate. It is one coil. Or you can call it auto resonance, because there is no need for resonance between primary and secondary.
And one coil is also inductor. So we can say that auto transformer is inductor also.
But, I don't want to go deep in subject. I tried only to show some small differences in type of design. So, yes, with design you can do things without capacitors and inductors.
What are the required ingrediënts for a working device ..
When you look at Kapanadze device, what you see? Not much. Coil (auto transformer??), capacitor...
So, all ingredients we already have. We just have to connect them properly. So major ingredient is our mind. We have to think.
I am not the smart guy, I do experiments and tests. Don't have the answers. Trying just as others do.
But I am not trying to build someone others methods like Akula or, you name it.
I do believe Kapanadze is genuine, that is why I am looking at his design, construct. For others, I don't know. They did it, that's for sure. But I don't have intention to decipher what they did and waste time on that. I am trying to make my own conclusions and then I test them.
Hope I helped, if not don't blame me.
Cheers! And I wish you luck!
WhatIsIt
I just looked at Kapanadze patent.
Everything looking nice, but something caught my attention.
The way he connected his coils?
Is it transformer or auto transformer?. Because that connection between winding's?
And part number 2, can it be that big coil which I think is capacitor?
Or is it just his way to fool the reader?
Or it is nothing?
Any thoughts?
AlienGrey
Yes my thoughts are your post is OFF TOPIC !
would you please create your own thread OR look in the directory and
Select an aproprialte KAPINAZE thread and post this stuff else where,
No offence intended but it's cluttering up this thread and if you bothered to search back
IN THIS THREAD I bet you would find this same post at least TEN TIMES.
Posted Soliman's drawing might be of help on this page for connecting or hooking up.
