0 Members and 1260 Guests are viewing this topic.
WhatIsIt
Quote from: r2fpl on June 09, 2019, 02:57:46 PM
https://youtu.be/INPIfDGfMGs?list=UUu1hNQsr9YnkIjFkMAc3Npw&t=9390
In this video he runs it only for 3 min.
Why he didn't leave it for 60 min.
He can't!
He have to shut it down after 3 min.
Don is useless! Period.
WhatIsIt
The most valuable currency in the world is not US Dollar or Euro!
No!
It is time we got!
T-1000
Quote from: NickZ on June 09, 2019, 03:20:06 PM
   T-1000:   Here's a little video that I just uploaded, concerning the Kacher's frequency and voltage tests on the Earth ground line.   Funny, even before I could post the link to the video below, there had already been several views of it on YouTube.
   https://youtu.be/YhRvQOyvkD4
Thanks for making video. So it is 1.63MHz? Is it same frequency when CT have plastic core and not ferrite?
Do you have 10 or 100 Ohm resistor across ground CT wires? It is needed there.
Here are few things I would like to see if they make difference:
1) The scope ground - what happens if you have it on mains ground instead and not the ground your test bench is using?
2) The grenade coil - would you able to make another one with all windings to one direction for testing? Like the one I shared previously - https://imgur.com/a/2OnO8Mk
3) It would be interesting to see if the push-pull can be tuned to odd frequency (with highest amplitude possible) of 1.63MHz and Tesla output on 1.63MHz with help of high voltage capacitor instead of ferrite rod. Wonder if you may get grenade output influenced. And if yes, the short bursts of Tesla coil on/off on peak of series resonance current on grenade inductor might improve output.
Cheers!
WhatIsIt
   EDIT:  Guys, do you think that you're going to figure out how Don Smith's devices work, without even building them?   How many years have people like at Energetic Forum and other forums been trying to replicate his work. Yet, no cigar.   Don never gave away his secret. Nor did Kapanadze, they would rather die, before spilling the beans. Old farts...
From your video I can see how much time you invested. Very clean and nice.
Man, i do appreciate what you have done.
Good luck! My best!
NickZ
Quote from: T-1000 on June 09, 2019, 07:58:57 PM
Cheers!
[/quote
   T-1000:  Ok, well I'll try to wind another torroid core (just an air core), and put a resistor on there, for the ground line test.I thought that the resistor should be there, but I didn't know what value it should be. So, thanks for that tip.
    I am not going to be making a new grenade, as I feel that the one that I have is made to the right specs, and is working as it should.
    Connecting the scope negative probes to different mains AC ground? Not the Earth ground? Sounds kind of strange, but I'll see what I can do about that. I do have TWO 37.5 meter Earth ground lines going to my water well that's in my back yard, also.   The push pull circuit will not go to 1.6MHz, like the Kacher circuit can. But, my Kacher has no guts, at 1.5, 1.6, or 1.8MHz, and just shows small one mm sparks, at those frequencies. It seams to run best at around 1Mhz, or so, depending on the load that's on the grenade. What size cap to substitute for the ferrite rod that's by the antenna coil?
    No matter how well the signals may look on the scope, the real proof is at the output. As a great looking signal, but showing a lousy output, is not good. So... the main thing for me at this point is to be able to run the feed back path, and to see at least a 10w bulb lighting, while the device is self running. Sometimes I feel that the using the scope is more of a distraction.I'll try to make any of the suggested changes to the device, one step at a time, otherwise, I could be out chasing turkeys, again.   I think that I have followed the TopRuslan 7 replication fairly closely, it was suppose to be a self runner, but, I have not been able to find the proper sync that allows for self running, as yet.
NickZ
