0 Members and 556 Guests are viewing this topic.
WhatIsIt
Quote from: T-1000 on June 11, 2019, 05:09:08 PM
On the right side in the video - ZVS style cicruit running on 50Hz stepping up voltage. Eats amps when running alone
On the left side of the video - flyback transformer with secondary coil with capacitor in series then discharging over fat coil inside of spark gap. Does not eat much amps if you make it resonant on flyback primary. And as the side note, in other similar videos it makes ZVS style circuit to stop eating amps while also increasing output.
The relationship between these two circuits is capacitive over air gap.
And it is simple enough to try replicate such experiment and to see effect for yourselves.
I was totally wrong, that explains everything, it makes sense!
Thanks!
AlienGrey
Quote from: WhatIsIt on June 11, 2019, 05:28:53 PM
Thanks!
All you need to know now is what the HV drive waveform is supposed to look like ?
a square wave or a pulse experimenting should find that
Jeg
Hi Arunas
It looks very much like the attached image of DS.
T-1000
Quote from: Jeg on June 12, 2019, 07:55:04 AM
Hi Arunas
It is similar but missing second power source for exact comparison.
And sudden HV spikes are more than just power transfer. It also includes current drag between ground and air by inertia which you want to collect on output for utilization.
Cheers!
NickZ
Quote from: T-1000 on June 11, 2019, 12:12:55 PM
Yes, it is current transformer. And if you can add up current going to the ground with the current on grenade inductor the power amplification should happen on grenade output with no opposite windings on its secondary coil.
Cheers!
   T-1000:
   Something like what Stalker is showing in this video below.  I can't understand most of it, but I think that I get the idea.  However, this CT is being tested on the 3t coil, not on the Earth ground line right?
    https://youtu.be/NGG8Hk68Ikw
