0 Members and 562 Guests are viewing this topic.
T-1000
Quote from: NickZ on June 13, 2019, 01:24:34 PM
   T-1000:
   Something like what Stalker is showing in this video below.  I can't understand most of it, but I think that I get the idea.  However, this CT is being tested on the 3t coil, not on the Earth ground line right?
    https://youtu.be/NGG8Hk68Ikw
In that video he explained how to tune current transformers for showing proper indication of current phase on 90 degrees in series resonance part from the yoke. This is done by changing resistor values and also then marking exact pins where scope pickup and ground was connected when getting correct readings.
The signal from CT is used in circuit pickup signal later on. Also he uses 2 resistors in series for producing less heating and protecting them going outside of measurement range and not letting them burn.
Also for the ground CT I suggested the frequency range is much higher(100kHz-5MHz, the ferrite cores are limited on that) so it will be bit more tricky to make it read current properly. And if it is exactly a case with max current from ground for proper device operation the output from this CT can become feedback signal for Tesla coil driver later on with proper circuit design.
Cheers!
AlienGrey
Nick T1000
Any chance you can show us how to setup the TL494 timing diagram ?
r2fpl
The rise effect is enhanced when grounding is connected to HV. There must be an appropriate frequency and type of pulses, in other cases there is no gain!
https://youtu.be/-eJBNyCn4_M
AlienGrey
Quote from: r2fpl on June 15, 2019, 02:17:48 PM
Well Dr Steven greer has given us a few hints about that over time regarding how aliens get here from miliilions of light years away if you could charge a huge capacitor or battery at that spread all your problems would be solved in this forum.
However as he also points out it would creat another one regarding Bull shit.  :o
r2fpl
Has anyone had a similar effect that can match this oscillogram? It looks like a negative resistance.
