0 Members and 619 Guests are viewing this topic.
AlienGrey
Quote from: r2fpl on June 15, 2019, 05:41:54 PM
Has anyone had a similar effect that can match this oscillogram? It looks like a negative resistance.
To do that doesn't require much imagination, the oscillograph shows a capacitor charging.
the second half is dumping the energy into some thing like a gas filled discharge tube.
Nothing special except it's charge time looks to be controlled.
NickZ
   I think that wave is called the sperm wave. Or a cut off fish wave.
   T-1000:
   Well as you may know, I've never been too fond of the idea of energy back from the ground line. I've always conceived it being the other way around, or energy going too the ground, instead. But, maybe it's both ways, instead of one or the other way. Like a static charge, just there. And energy may flow both ways, at once.   So, to test such an idea, I thought to place an air core coil (as suggested), which is tuned to resonance at about 13MHz, or so. And place it on the Earth ground line to see what happens, and what the signal looks like, as it can pick up much higher frequencies, in the MHz range. So, what value resistor do you think that I should place on that coil? It's not going to cook, as there is not much amperage on the ground line, normally. Geo had shown how he could light a bulb on his ground line, but, I never tried it. I don't like to disconnect the ground line when the device is running.
   Anyways, let me know what you think.                                                            NickZ
NickZ
Quote from: AlienGrey on June 13, 2019, 05:15:24 PM
Nick T1000
Any chance you can show us how to setup the TL494 timing diagram ?
   AG:   This (below) is the diagram of the basic TL494 circuit that I've built and replicated, and is in use for my induction circuit. But my device was made by a combination of three different TL494 circuits all combined into one. However, it still basically a replication of the diagram below.
r2fpl
Quote from: AlienGrey on June 15, 2019, 07:04:58 PM
There is no capacitor in the circuit and spark gap is not responsible for it.
AlienGrey
Quote from: r2fpl on June 16, 2019, 03:12:54 AM
go back in this thread that video is just a copy of Grey's motor tube
seen it before and made that device and circuit up timing is important and
some plugs have 'r' others don't .
Experiment your self is crucial.
