0 Members and 18 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on June 18, 2019, 05:32:59 AM
If to approach whole concept as mixed transformation with inductive Tesla coil (push-pulll and grenade coil)+capacitive static transformation from second Tesla coil (katcher circuit and "antenna" on top of grrenade's inductor) you end up adding ground current into mix. It may not be seen much in amperes but because there is high voltage involved in open circuit it counts towards decent power.
The CT on high frequency - just need to make sure it does not filter out frequency range on which Tesla coil works on with best ground response and CT does not ring itself on that frequency range.
The rest can be found out more on experimenting as no one did provide enough data from results before.
Cheers!
Hmm so what is CT? Computed tomography ? Cream Tea, Cooked toast ?
NickZ
   AG:
   Looks like you have not been following this thread.
   I have posted a video by Stalker explaining what the "CT" is, and how he uses it. Known as a "current transformer", once again.   T's idea is different, as he thinks that there is current to be had from the Earth ground line. That, I have not seen. Although I don't know what gives him that idea, but, it may be important to run the CT from the 3t coil circuit instead, as Stalker is showing.   I have not been well lately, and is the reason that I have not continued the tests. But, I will. I'm in no rush, for now.
AlienGrey
Quote from: NickZ on June 18, 2019, 09:31:50 AM
   AG:
Have you seen the price of a current probe I use a Hall linear device it works up to 200 khz it measures magnetic Gauss but any wire carrying current produces a magnetic field as in that wave form i showed you but it's not what i'm telling you that's important !
NickZ
   AG:
   Remember, I am focused on my type of repication, and not jumping around to other videos and circuits.
AlienGrey
Quote from: NickZ on June 18, 2019, 12:05:04 PM
   AG:
   Remember, I am focused on my type of replication, and not jumping around to other videos and circuits.
We were discussing test equipment last now you have switched to designs of Ruslans fantasy fascinating!
