0 Members and 709 Guests are viewing this topic.
saturnio
Quote from: NickZ on June 23, 2019, 11:25:10 AM
   Geo, T-1000:   Here is a video that I made last night.  At the beginning of the video, it can be seen that the CT is showing 3.2MHz, at times.   https://youtu.be/u_gg73t5GaU
   Here is a pic of the CT, (air core this time). It was tuned previously to about 3.5MHz- to 4MHz. This was with NO Kacher running, just the induction circuits. With the Kacher on the CT voltage is higher, or course. I will show that next time.
Hi Nick, why did you use a solenoid to pick up current from ground cable?? It should be a toroid...
NickZ
   Well, because I had several of those type coils on hand tuned to known frequencies in the MHz range, and I wanted to see what it would do. Some guys say that the CT needs to a ferrite torroid, some say it need to be an air core, for the MHz ranges. I thought that I'd try the simple straight coil, instead. But, an air core torroid can be made, as well.
   I don't really buy the idea about tapping into current from the ground. And, how would you prove that any shown current on a scope is not coming just from the input source, instead? Will the scope tell me if it's coming from the ground. I don't think so...   Anyways, just trying some thing out...
   Hoppy:  Thanks for the clarifications.
   I can connect the circuit up to two 12v batteries, it's just that they don't last more that a few minutes before starting to drain.
   So, for testing I'm using two laptop adapters, a 18v 6A one for the induction circuits, and a 24v, 2A one for the Kacher circuit.
But, I can do the test with the batteries, as well. What would be the point though? To avoid stray AC? Or what?   Below is a blurry pic of the ground CT running at 3.21MHz.  I'll post a better one later.
AlienGrey
Have you watched the Vasmos video's, there is one video i'm thinking of where he is out in a field
with his device and he has a clamp meter guess what he uses the clamp meter to measure the current !
There is another video where Kapanadze does the same thing in Turkey. Good aye it  ;D
Hoppy
Quote from: NickZ on June 23, 2019, 03:15:46 PM
A few minutes is all that's required to take a screen shot from your scope. You may not see the same current waveform. If so, we can then determine why.  ;)
AlienGrey
Quote from: Hoppy on June 23, 2019, 03:54:40 PM
is he checking where the current wave is on the timing order or the ground current ?
With your CT do-dar-dit you can get a phase shift and a phase inversion depending on frequency.
Are you sure using his scope wouldn't be a better idea ? at least to set it up, be aware Acula does exactly that
except no one has bothered to translate it.
