0 Members and 473 Guests are viewing this topic.
AlienGrey
AlienGrey
AlienGrey
Quote from: magpwr on February 20, 2016, 10:55:38 PM
hi everone,
Someone mentioned in youtube that clamp meter isn't a good way to detect current movement to Earth related to my Tesla Transponder 2.0 video - http://www.youtube.com/watch?v=Yun3HjsNNKs
Since i do not own a 1 Ohms resistor although i do own a 0.1 ohms 100watt non inductive resistor. :D :D
Since i am dead sure there is current to Earth from 12volts battery which is isolated from grid.
I have quickly assembled a 1 turn on a blue toroid which can handle high frequency in Mhz.
This simple quick test revealed that at 1 turn the spike is around 2.9volts in order successfully to light my 10mm white Led.
Any engineer in this field will know that this is easy way to reveal current without going into the exact measurement."Time saver"
Please don't fall for lame test where anyone show lighting a bulb from tesla coil to Earth.Remember as the voltage goes up the current goes down.
Tariel is indeed different from Tesla because Tariel focus was on current movement to Earth and Tesla did ever light a bulb few feet/meter from tesla coil.
Think in nature the voltage built up/ionization mainly happens in the sky but Earth definitely provide the current in the case of lightning strike.The only word i can think is counterpoise base on my current education level. :D :D :D
Many still thinks that the iron core transformer can't go higher than 400hz.Only provided that the pulse width is kept very narrow below 100 nanosecond .But to be exact it's around 78 to 80 nanosecond
There is iron core present on the clamp meter loop/clamp.
In other words what i am trying to say the iron core will hardly get saturated in nanosecond range.
The only thing is true the reading on clamp meter won't be accurate.
But hey i was following what Akula was doing in video given the error of measurement shown on clamp meter and i am able to replicate the current Reading
easily. :D
To wrap it up all of us were following wrong way of implemented kacher and worst playing safe voltage at 12 or 24volts which makes this setup even more laughable.
As already mentioned in my previous posting few hours back we need to start working with voltage as high as 150volts...200volts or even 250volts dc for the kacher.
If you need to see current reading to Earth and if you are serious about your replication project.
My next stage is to test if my version of kacher can be powered(100volts to 180volts.But i am aiming high at 200volts on pulse capacitor 20uf Russian PIO capacitor 400volts) merely  from the BEMF generated without "Taxing" the source battery.
I will reveal once basic setup is tested. :) :) :) 8)
Magpwrs earth detector
lost_bro
Quote from: AlienGrey on June 25, 2019, 10:50:21 AM
Good day all:
Yes, Magpwr is dead on with his observation:  There is current in the groundline,  but it is NOT that simple:
https://www.youtube.com/watch?v=__Idc66i-30
I made the video after I saw that a 100watt incandescent light bulb could be lit to full brightness w/ the ground line of a SSTC (solid state Tesla coil).
So in this video I used an inverter to power the entire SSTC, NO connections to the public utility ( house is 100% solar).
The incandescent light bulb is connected in series w/ the ground line at the base of the SSTC.  The ground line is about 10 meters long of #10 awg copper wire.
But as I mentioned in :
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #21487 on: June 24, 2019, 09:46:12 PM »,      the ground line is a complex beast:
The topload of the SSTC is capacitively coupled to ground, and the ground line is the *return* for the current from the capacitively coupled topload.  There is no mystery here.
Reason:  this is because the **ac reactance** of the 10 meter ground line comes into play and the base of the SSTC where the 100 watt bulb is placed in series  does NOT *see* the actual ground potential but experiences a partial voltage anti-node (this depends on operating frequency and ground line length).
The SSTC base, where the ground line connects is NOT at true ground potential and therefore the bulb *sees* an elevated voltage and amperage, enough to actually explode the 100 watt bulb.
The _Trick_ in my opinon would be to manipulate this ground line ac reactance to shift the magnetic / electric components of the wave to where they are needed most in the device.  This is what it seems Ruslan and Akula were attempting / doing with the *coiled-up* ground line.
take care, peace
lost_bro
