0 Members and 269 Guests are viewing this topic.
NickZ
   Guys:   So, here's another little video that I uploaded last night to YT.   https://youtu.be/9UxOvZatzKY
T-1000
Quote from: NickZ on July 03, 2019, 11:52:59 AM
Nice to see your bulb flashes brightly when actually trying to match frequency with ground current. Wonder if you would be able to make it more consistent and explode that bulb... ;) Then if you manage to explode 300W bulb that will indicate good results (just joking).
Some things to try when it is that mode:
1) Do sparking to the ground line from end of "antenna" improve effect or make it worse?
2) To make effect more stable - does bringing grounded metallic plate near top of Tesla coil help? While bringing nearby it effectively changes Tesla coil resonant frequency.
3) When having effect on maximum - does modulation with brief on/off around max current on yoke output increase effect even more?
P.S> The power supply from mains definitely need to be removed in order to avoid mains current loops over ground line.
Cheers!
Hoppy
Nick,
The 'effect' is back.  :) 8) Are you monitoring supply current whilst moving hand around grenade? Good to see that you are back on a battery supply for the induction circuit and finding good use for your scope. The Kacher HV now appears to be affecting the push-pull mosfets like I experienced.
AlienGrey
The thing is how to explain. the lithuanian guy the master has his katcher tuned, so did color caps on pri and sec but
he didn't say if the katcher assembly was linked to the golden ratio ie 5,  3,  1, or not but i dont think 1.8 mh ect
as his scope pics show some thing different as his 1.something megs goes into an inner pvc tube in the centre of
the grenade assembly. like SR193 and Daily device
and so on ect
AG
NickZ
Quote from: Hoppy on July 03, 2019, 01:52:29 PM
Nick,
   Well, I'm just very glad to get the effect back, as it's been over a year since I heard Radio Moscow. Now at least I can try tuning, where as before there was no "effect" at all.    I'll tell you though, it may be very hard to prove and show accurate readings like you would like to see. Connect the scope negative up to the device and you kill the HV pulses as well as the resonanace between the HV and the induction circuit. Period.
   Monitoring input to output readings are almost impossible. At least from what I can see.
   I will separate the Kacher from the grid connection. But, I already know what will happen when the scope negative is on the device, Zilch, as it will still ground the Kacher's HV to the grids ground line. It becomes a short circuit, to the HV, as I showed in one of the videos.
   Of course the HV affect the mosfets, they now run much cooler when running like I showed in the last video, even with no fans on. But, using the wrong frequency, and those fets are untouchable in one minute. However, both fets ARE working, not just one.
