0 Members and 769 Guests are viewing this topic.
T-1000
Quote from: NickZ on July 23, 2019, 03:38:45 PM
   T:  In order to see results on a video, we need a clear idea of what you are trying to say.
    Perhaps you can explain details on the phone, to apecore and he can then explain them to me.
     I've have no problems ever with apecore on this forum, nor or anyone else. And we are most always friendly, especially when not insulted, like some people still like to do, elsewhere, on other threads.
   What kind of coil capacitor is that diagram showing?   And no, the secondary of the Kacher circuit can't run at the same frequency as the grenade output coil. As the output coil can't oscillate at the MHz ranges, like the Kacher can. So, if I missed something, please explain.
No offence, my explaining over forum makes much more confusion than explaining over voice communications.
apecore already knows what to do for idea testing and for yourself - just install Skype and get into call for once.
For capacitor - 2x home made 3-5 cm wide single layer aluminium foil coils, connected only one end to wire each, insulated between to withstand high voltage. The length of top one can be changed so capacity and induction changes. The aim is to make electrostatic transformation so cpacitors gets charged and the current from the ground starts flowing.
For grenade - who told you it need to work in MHz range with such long wires? The inductor is up to 100kHz top and can only work on resonant harmonics while keeping whole grenade magnetised. And the secondary of it - lots of variations but in the end it should induce enough output voltage. No full cancelation there apparently.
So here it goes...
NickZ
   T:    Ok, I understand that it may not be too easy to explain technical things like that on forum posts, but I still need more details. As I still don't know what kind of capacitor you are suggesting, like what mf, or voltage capacity, or why a commercially made capacitors are not good enough.   Please try to explain your full idea to apecore, so that I can call him on WhatsApp, as I have done many times before. I don't use, nor want to use Skype. As most everyone is now using WhatsApp.
   BTW: Is Geo lost in space again?
   T, what I'm trying to do is to obtain enough output from my grenade/kacher set up, to at least be able to fire up the feed back PS, and self run the device, with NO load on. That is my first and main objective, at this time.
   I can't tell if there is any current coming from the ground, or is just going to the ground, as is normal. But, it's not enough in any case to self run, so far. It certainly is getting very close to it, though. And, I'm not giving up, I just need a little more inspiration. However, I am trying to maintain a close to true Ruslan/Stalker type of replication, and not deviate too far off from what they had shown, such as the TopRuslan 7 design.
   Apecore, Geo, and Jeg, (or Jed) are further along than I am, with their controllable Kacher circuits, but they are still not self running, either, nor showing a higher output than what I've seen with my device, so far.    Tariel didn't need a controlable Kacher circuit, to show what he showed in his first few videos self running 4000 to 5000w worth of bulbs. And no one has proven those devices to be faked.
   I do love simple devices, the simpler the better.   As the Russians are the only ones with self runners, we need to communicate with one of them that can help us out, here. And that are willing to show us step by step, what is actually needed, and what is not. Otherwise, it may be a few more years to see some more positive results, the way we are going at it now.
   As apecore knows what you are telling us, I'll wait to see what he comes up with, before diving in myself.
   Cheers,              NickZ
Grumage
Hi Arunas.
As you know I'm in semi retirement from this area of research as for the last 3 and a half years I've been running my home on the DSE. No, not the Don Smith effect, even better.....
Direct Sunlight Effect!!   :)
Joking aside, I wonder if this little demonstration has any relevance to the current line of research. It has recently been suggested that the length of wire was acting as a capacitor.
https://youtu.be/wNBuUvHDe1k
On a different note, I too am a little concerned about the present situation here at OU.Com.
The site owner has effectively " gagged " some of the most knowledgeable members here from contributing, a sad day indeed.
Cheers Graham.
ramset
Taking hoppy out of this topic ... for shock treatments ??
we're not gonna like that !!
And I don't think Shock treatments work on AG...he's been zapped too many times...resistant
Thanks Grandma
r2fpl
Quote from: Grumage on July 24, 2019, 06:46:55 AM
Hi Arunas.
Cheers Graham.
If you replace the wire with a 10-200nF capacitor, it will have an even better result. Yes the cable is a capacitor.
