0 Members and 596 Guests are viewing this topic.
Void
I had little time, so this is a quick test of three basic test configurations utilizing the following:
12V 7Ah SLA battery
HV flyback driver (isolated from ground)
sparkgap
L1 - air core coil - 225 uH approx.
C1 - HV capacitor - 0.1uF, 10,000 Volts
Earth ground wire connected to copper cold water pipe
1000x scope voltage probe - measuring voltage waveform across the coil L1
scope current probe  - measuring the earth ground wire current waveform
Test Purpose:
Compare L1 coil voltage waveform and earth ground wire current waveforms for three different configurations:
1 - Sparkgap to coil to earth ground.
2 - Sparkgap to coil and cap in parallel to earth ground.
3 - Sparkgap to coil to cap in series to earth ground.
Test Results:
Nothing too overly amazing. :)
Looks like I got the most prominent earth ground wire current waveform when the coil and cap were in parallel,
which is a bit surprising to me. I would have thought that would happen when the coil and cap were in series.
See the attached screen shots of the scope waveforms for each of the three test configurations.
Last picture is a picture of the actual test setup when the cap was connected in parallel.
Nice L1 coil. That's how a high-Q coil is constructed, the radio guys know. Black PVC is conductive enough to cause problems in EHV systems.
That table lamp is crying out to be used as an elevated capacity.....
:D
Raycathode
Void hello, nice setup, now you have your set up shown can i ask you to do a test as shown in JB set up
also you might need a Resister in series to set up RC charge time for dump in the top -ve line to your very nicely wound coil.
Kind regards Raymondo
PS I will try and find JB's demo phone video and post later
Be aware after AG loading a pointing this video out to RF on the troubled thread it has been deleted
strange that after being on UT some 3-4 years. Did any one save it ? I only saved pointer.
https://www.youtube.com/watch?v=9Flj6i0zQ-7&feature=youtu.be
kolbacict
Isn't the explanation of the mechanical generator Kapanadze here?
QuoteWe want the device Kapanadze to have such a design, as we want, and not as it really is.
T-1000
Quote from: Void on July 27, 2019, 12:55:25 AM
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/173691/
Thanks for a test, this basically confirms a case where we have Tesla coil and "antenna" over inductor of grenade coil. All you need is to quench spark gap for narrow spark interruption (might be strong magnet in spark gap) and amplify effect on ground line. Then find arrangement which amplify magnetic field on grenade inductor...
P.S> the virtual capacitor (instead of capacitor in a test) on grenade consist of "antenna" and inductor. Both inductive and can cause additional magnetic field in arrangement.
Cheers!
