0 Members and 61 Guests are viewing this topic.
kolbacict
QuoteHi kolbacict: Sorry, I can't read Russian. Can you explain a little bit what the concept is?
It seems from Patrick Kelly. Only I can not find. 3000 pages. All the same .. Translated by Utkin.
And the essence, the meaning of the quadratic dependence of the kinetic energy of a moving ball on speed.
Raycathode
Quote from: kolbacict on July 28, 2019, 04:30:37 AM
Hmm I made some of Kellys 'worthless trinkets' none of them turned out to worthy of 'OU' title  :'( :'(
No offence in tended but Have you tried google translate emphasized in hope you see it   :D :D ;)
kolbacict
It is difficult to translate because it is not a text, but a picture. as well.
The principle of amplification of mechanical energy.
Explanation. The principle is based on an asymmetric flywheel (1) consisting of a small and a large mass. The masses are balanced relative to the center of rotation at a distance inversely proportional to their masses. When rotating, this eliminates the beating (the principle of the automobile wheel)
In terms of the moment of inertia, such a flywheel is similar to a flywheel consisting of one large masses (2) or a flywheel consisting of single small masses. (3) However, from the point of view of kinetic energy, depending on the linear velocity of mass movement (the speed at which the masses fly if release them) the energies of the flywheels (1) (2) (3) are different. The masses in the flywheel (3) have the highest total mass, the masses in the flywheel (1) and the smallest in the flywheel (2)
To get a gain in energy, it is necessary to make some device based on a mechanical spring (converting kinetic energy into potential energy and back), as well as the Archimedes lever (to change the point of application of force)
remarks.
1. The presented diagram is purely conditional to explain the principle of operation.
2. In a real device, as a spring you need to use a spiral in twisting mode (like a device by Tariel Kapanadze)
3. As the masses need to use discs and rings of different diameters (like the device of Tariel Kapanadze)
4. Replacing one mass to another is reduced to connecting different disks.
Comment.
The asymmetric mechanical oscillator behaves in a similar way when the potential energy of the compressed spring passes into the kinetic energy of mass motion.
The potential energy of the spring is not evenly distributed between the masses.
Less mass gets more energy. The sum of these energies is equal to the energy of the spring.
Comment.
Based on the Tesla asymmetric scheme.
Flywheel-hidden energy form
(explanation of the enhancement of mechanical energy)
Explanation. If you do not want to lose mechanical energy in the course of work, then this work must be performed by an imaginary force. This means that the force is absent in the inertial coordinate system, but is present in the non-inertial coordinate system. This force in the rotating coordinate system is centrifugal force.
Comment. After the work is done, the centrifugal force will be small and if you want to continue generating energy you must use a coordinate system where the centrifugal force is high again. This is possible because the linear velocity has not changed.
You must change the fulcrum (and also the thread) in order to achieve this goal.
Comment.
If you want to perform mechanical work continuously, then the beginning of the first trajectory should be the end of the second trajectory. You will have to periodically change the coordinate system.
Void
Thank you for the explanation kolbacict.
I have seen videos of Kapanadze's mechanical generators for which some did appear
to have unbalanced (asymmetric) flywheels. Kapanadze also demonstrated a 'hydraulic' self sustaining generator,
which one might think works quite differently.
If those apparently quite different devices and Kapanadze's electronic devices all work
on some similar principle, I can't imagine what the principle would be.
P.S.
Here are some old videos of some of Kapanadze's non-electronic devices, which I posted to
Wesley's thread some time ago. Really interesting if they all really are self-sustaining:
Установка Tariel Kapanadze/Тариеля Капанадзе (Одна из первых демонстраций)
Installation Tariel Kapanadze / Tariel Kapanadze (One of the first demonstrations)
(Some weird looking generator)
https://www.youtube.com/watch?v=2G8PVTKtOzA
Установка Tariel Kapanadze/Тариеля Капанадзе (Униполярка)
Setting Up Tariel Kapanadze / Tariella Kapanadze (Unipolary)
(Disc generators and a car engine running on water?)
(Edit: I don't see Kapanadze in the car engine demo part, but Kapanadze has mentioned once that he had such an invention)
https://www.youtube.com/watch?v=7JQSyQAVqzc
Гидравлический генератор Капанадзе 3 2015(сентябрь)
Hydraulic generator Kapanadze 3 2015 (September)
(self runs and lights up a bunch of lights)
https://www.youtube.com/watch?v=pdVLbev859M
There are a few more interesting Kapanadze videos on that same Youtube account some people
may not have seen before.
kolbacict
And how much is this principle possible to make realized, which is described in those pictures?
And could Kapanadze do it?
  p.s. Wesley would do it better, insert text into pictures. :)
