0 Members and 117 Guests are viewing this topic.
bringdownthezog
Quote from: Grumage on August 13, 2013, 08:12:52 AM
Dear bringdownthezog.
Not so. Please see here.
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg361673/#msg361673
I had a little tinker. I got 30 seconds of free running, and a couple of catastrophic capacitor explosions. Something I have never seen before in testing such a "benign looking circuit"!!
Cheers Grum.
Dear Grum,
I did a scan of the other thread to check if this circuit was posted.
Thanks for that link.
The image with the comment 'Transformer not important' is not quite correct. It is actually a stack of two toroids and is essential for the working of this device. So is the kind of wire used on this stack of toroids.
http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Telephone/
Cheers,
screen
In this video I can already extract the voltage at 3 inductor, this inductor remembering that the output is low on the primary, about 200 mA. I'll behind a microwave choke to increase the load capacity is consumed. Video: http://www.youtube.com/watch?v=yiBtqPN_l5w
NickZ
   The more I study the reasons that the Akula type of circuit may work, the more I'm seeing that the inductor heater type of oscillator's circuit with an output of low voltage and higher amps, combined on the same yoke core with a high voltage low amp input source, may be the cause of the special reactions taking place. It looks like Akula first worked on making the induction oscillator circuits, to heat the wrench inside the toroid coil, and from this idea was developed the addition of a high voltage coil wound with 25 turns on the yoke core, and provided by rectified 220v DC votage.  The 25 winds coil was placed on the same ferrite yoke core, so, these two separate coils the 12 plus 12 center taped coil, are working together somehow, and the thick 3 turn yoke output coil is very much like what is used on the induction heaters output core coil, that lead to the pancake coil, or to the coil made of copper tube or solid copper wire.
  I believe that Igor Moroz is now in the process of making his own induction oscillator coil circuit to replace the commercial made induction cooker circuit that he was using previously. As that commercial unit will not work well when trying to feed it with his modified sign wave inverter. So, we'll hopefully soon see some new results along those lines.
He mentioned to me that any diode type that is high frequency high current would be suitable for this purpose, for making a full wave bridge rectifier.  Maybe these diodes can possibly be obtained even from Radio Shack. And Grumage, yes these diodes do heat up when dealing with outputs 2kw or more, so he uses 1.200 watts of Halogen bulbs, as a buffer to keep the diodes from going up in smoke. And, it looks like his system need at least 500 to 600 watts of load to work properly with the induction oscillator circuit. That I see as a disadvantage, but, maybe its not as long as it's all free energy.
NickZ
   Wesley
  After several months of watching most of your videos including the last one that you just posted, which I viewed three times, and hearing you talking about free energy revolution, saving the world, etz...    I must have missed the part where you are showing how the Colman device, is going to help us with that.
   Have you or your visitor in the last video, or anyone else, been able to show any type of Colman device lighting up a simple light bulb, or producing ANY type of output, on its own yet, or not?
I don't mean radiation, such as Alfa, Beta, etz...   I mean electric power, useable electric power
  If so, please direct me to it.
