0 Members and 665 Guests are viewing this topic.
ARMCORTEX
Where is this quote from Kolbacit taken from? Kolbacit, who are you replying to? Please quite with name
It is difficult to translate because it is not a text, but a picture. as well.
The principle of amplification of mechanical energy.
Explanation. The principle is based on an asymmetric flywheel (1) consisting of a small and a large mass. The masses are balanced relative to the center of rotation at a distance inversely proportional to their masses. When rotating, this eliminates the beating (the principle of the automobile wheel)
In terms of the moment of inertia, such a flywheel is similar to a flywheel consisting of one large masses (2) or a flywheel consisting of single small masses. (3) However, from the point of view of kinetic energy, depending on the linear velocity of mass movement (the speed at which the masses fly if release them) the energies of the flywheels (1) (2) (3) are different. The masses in the flywheel (3) have the highest total mass, the masses in the flywheel (1) and the smallest in the flywheel (2)
To get a gain in energy, it is necessary to make some device based on a mechanical spring (converting kinetic energy into potential energy and back), as well as the Archimedes lever (to change the point of application of force)
remarks.
1. The presented diagram is purely conditional to explain the principle of operation.
2. In a real device, as a spring you need to use a spiral in twisting mode (like a device by Tariel Kapanadze)
3. As the masses need to use discs and rings of different diameters (like the device of Tariel Kapanadze)
4. Replacing one mass to another is reduced to connecting different disks.
Comment.
The asymmetric mechanical oscillator behaves in a similar way when the potential energy of the compressed spring passes into the kinetic energy of mass motion.
The potential energy of the spring is not evenly distributed between the masses.
Less mass gets more energy. The sum of these energies is equal to the energy of the spring.
Comment.
Based on the Tesla asymmetric scheme.
Flywheel-hidden energy form
(explanation of the enhancement of mechanical energy)
Explanation. If you do not want to lose mechanical energy in the course of work, then this work must be performed by an imaginary force. This means that the force is absent in the inertial coordinate system, but is present in the non-inertial coordinate system. This force in the rotating coordinate system is centrifugal force.
Comment. After the work is done, the centrifugal force will be small and if you want to continue generating energy you must use a coordinate system where the centrifugal force is high again. This is possible because the linear velocity has not changed.
You must change the fulcrum (and also the thread) in order to achieve this goal.
Comment.
If you want to perform mechanical work continuously, then the beginning of the first trajectory should be the end of the second trajectory. You will have to periodically change the coordinate system.
What is this also? Another quote from Kolbacit
It seems from Patrick Kelly. Only I can not find. 3000 pages. All the same .. Translated by Utkin.
And the essence, the meaning of the quadratic dependence of the kinetic energy of a moving ball on speed.
rakarskiy
The flywheel will not run continuously, giving out torque power. This is an energy storage device (inaccurate analog, electric capacitor). Even if you do asymmetric loads, there will still be a resultant, which will balance the performance for the Moment of the pulse issued through the shaft. When you accelerate the flywheel to a certain speed, there are also forces that physicists do not like to fight. Centrifugal force and centripetal force. At some point, the energy storage develops into a quadratic increase, with the input torque required is negligible. If you discharge the flywheel impulsively, allowing him to restore the charge of the flywheel, less input torque, on the removal you can get a difference greater than the input.
I have developed a method of calculating the flywheel, based on traditional techniques and using indicators of centrifugal forces.  In any case, the use of a flywheel, better integrating it into the rotor of the booster system where torque is supplemented by motor torque of the flywheel.
If you make a calculation and graph of the stored energy and torque for the flywheel, you will see that the energy accumulates nonlinearly. And here is figure torque linear, that not can be in principle.
All this I have described in detail in my work
ARMCORTEX
What do your mean? Kapanadze has no overunity flywheel engine? Video seems to show self-power.
I already got your russian book Rakarsky.
kolbacict
rakarskiy
Quote from: ARMCORTEX on September 18, 2019, 01:38:48 PM
Living in Chelyabinsk, you can read in Russian  ;)
Kapanadze has an electrohydroshock. He has a flywheel for stabilization, as in small communal hydraulic power generation systems.
