0 Members and 363 Guests are viewing this topic.
Raycathode
Something is going on here it won't let me upload a modification I have found that draws far less current than the Tesla kacher I found it on the net and worked it backward and it looks good when I tried it but it might need others to play with it.
T-1000
Quote from: Raycathode on October 03, 2019, 08:02:24 AM
Original Lithuanian Experiment
http://freeenergylt.narod.ru/index/0-17
https://www.youtube.com/watch?time_continue=18&v=hDXEC6GeGA0
Hi,
This is taken back from 2010 Lithuania Experiment.
It was Caduceus coil as primary and Don Smith style middle tap secondary. The important factors there was single line Avramenko plug charging capacitor which was discharging into primary LC then both taps from primary and middle of secondary connected to flyback output as capacitor plates. The primary/secondary masses was equal and the wire length ratio was 1:4. Also we had ferrite rod for magnetic field transition which allowed to charge output capacitor much better. Also the flyback transformer was running on LC resonance and this was all load primary power source had on.
The output capacitor is charged from inductance of secondary coil. So we have capacitor as primary power source load and using inductance of capacitor plate to power output loads. Which is not enough alone to charge output capacitor quickly so addition of ferrite is kick-starting secondary process which involves power source from ambient.
Cheers!
Raycathode
Hi, T1000 It's an interesting design and find while looking at another pointer from one of Wesley's threads.
What I find confusing is the definition of how the caducous wind works without, building one.
Both IVO and Nelson's warning of sucking of pure energy from its surroundings (if such a phenomenon exists).
Therefore it must be important for its frequency chosen and how it is tuned.
Is it the length of wire between nodes or the distance of each node and wave shape
of the winding architecture as it's function again a pointer on (Wesley's thread) is to knock out the magnetic wave leaving only a 'dielectric punch' assuming this is so.
Has anyone any experience with such a device or any useful knowledge that might be of use 'here' or am I out on a thin limb with my curiosity and known experience?
kolbacict
Well, I did. About two years ago. It didn't work out. I hope I tried poorly. I want to ask Wesley for a long time, but I'm shy.
