0 Members and 71 Guests are viewing this topic.
NickZ
  The one askìng for assistance needs to provide some answers to his request.Lìke why he thinks his device may have some merit. And why he can't provide a schematic, nor show a video, as that is the minimum that is to be expected, to be taken seriously.
Void
Off Topic:
In case anyone is interested in what I have been up to in the past year,
I have been running a lot of experiments on Bedini type circuit  arrangements such
as the Bedini-Bearden battery 'back popping' setup, ...and I mean a lot of experiments.  :)
So far, no magic at all. Always runs the SLA battery down, as would be expected in an under-unity
situation. Here's an example of my most recent testing:
In this test, I am pulsing a 10,000uF capacitor with short duration flyback pulses to slowly ramp charge the capacitor
up to about 38V in 2 seconds, and then discharging the capacitor in a quick discharge pulse back to the
5Ah 12V SLA battery every two seconds (0.5 Hz). I have tried different discharge frequencies, but so far no magic seen.
The battery does something interesting where when you first start the circuit on a fresh battery,
the battery voltage (under load) quickly drops to say around 12.5 V, and then the under-load battery voltage
will slowly ramp up to say 12.6V or higher (depends on the current draw on the battery),
and may hold or climb further a little bit for up to an hour, but then the battery voltage begins to slowly and steadily
keep falling after that. The fact that the battery seems to gain in voltage while under load for the first half an hour to
an hour is interesting, but demonstrates the importance of running experiments using a battery for a long
enough duration so you can really get a clear idea whether the battery is discharging or not.
Scope shots:
Yellow shows the pulses to the switch which is pulse charging the capacitor.
Pink is the discharge 'back pop' current pulses from the charged cap back into the SLA battery.
About 18A peak approx., short duration discharge pulses.
P.S. The cap discharge current peaks may be somewhat higher than 18A, but my current probe
is not so great and may not be fast enough or may be saturating and not able to pick up the actual current peaks.
At any rate, the SLA battery is getting some relatively large (compared to the battery's Amp-hour rating) short duration
current back pulses every two seconds.
Blue shows the capacitor voltage as it charges and discharges.
The steady (continuous) average current draw from the SLA battery to charge the capacitor is about 0.42 Amps.
That's a fairly significant continuous load for a 5Ah 12V battery.
DavidWolff
Quote from: NickZ on March 01, 2020, 10:15:24 PM
  The one asking for assistance needs to provide some answers to his request. Like why he thinks his device may have some merit. And why he can't provide a schematic, nor show a video, as that is the minimum that is to be expected, to be taken seriously.
Well now why do you ask, what possible motive would some one have behind it all ask your self that, then you will find your answer.
And I have an OFF TOPIC question for Void JB had a circuit with a two capacitor parallel charge and a series discharge into a lead acid battery.
Witch JB seriously promoted Question did you prove that circuit?
I cannot post the schematic as it is copy write.
Dave
NickZ
Quote from: DavidWolff on March 02, 2020, 03:41:09 AM
Dave
Dave:   I don't need to ask myself what motive he may have.  I am asking why he thinks that he has a device that provides for OU, and shows some merit. This is not a riddle. Just trying to avoid more unneeded dead ends, if possible. As that is All that we've ever seen.
   We have had several people that only waste our time with endless BS. And is why I am asking him.
DavidWolff
Quote from: NickZ on March 02, 2020, 08:01:23 AM
Well I have been going through some of EMjs thread some where in the first 100 pages
one of the guys says about the 3.5KV pulse if it went faster in the Nano range or Pico range bending the flow then an ordinary
Wire becomes none linier a supper conductor like a piece of zinc wire where weird things happen I don't know
What he really means perhaps we all wake up from this night mare  ;D ;D
PS I mean would you give some one your exact location just for free energy? When some particle beam weapon could just fry the block where you live.
Dave
