0 Members and 1020 Guests are viewing this topic.
NickZ
   So, you think that both Akula's and Stalker's scope shots are wrong and misleading???   If so, please explain yourself, or don't, it's up to you. I see nothing wrong with Stalker's scope shot. I did not post Akula's scope shot. However, I think that you may not know what you are actually seeing there.
   Have you tried to built any of this type of self running device? If so, please show how you think these contraptions should work.I'd also like to see you figure this out yourself.
DavidWolff
Quote from: NickZ on April 18, 2020, 08:16:19 AM
   So, you think that both Akula's and Stalker's scope shots are wrong and misleading???   If so, please explain yourself, or don't, it's up to you. I see nothing wrong.
Well the peek sine wave is in fact a magnetic wave and pulsing another magnetic wave above and below the blotch zero line = nothing because it cancels out in order to have an effect you would have to cut off the sine wave electronically and then there is the cancelled pulse that's cancelled out any way.
8) 8)
Further the waveform cathode ray copied from way back a couple of posts up  could also be misleading
as it does not show the amplitude of any of the signals  but does depict the locking idea.
but what no one has ever commented on is the larger wave form is the slowest wave form and yet some
One who originally posted it says it is the out put wave !!!
So it's a lose making machine ;D ;D ;D ;D ;D ;D ;D ;D  and yet no one commented on it Its fundamental knowledge
Not even T1000  !    :'( :'(
The more sine waves the faster the speed the more efficient it bcomes.
NickZ
   David:
    There is only one "magnetic" wave there, which is from the push pull circuit running at around 16.5KHz. The other wave form is from the Kacher and it's HV pulse, which is running at much higher voltage, around 3000v, and at around 1.4MHz or so.  The Stalker's scope shot that I posted is showing just where the Kacher is supposed to fire, which he shows to be on the negative (bottom) or valley side of the (magnetic non shocking) push pull's wave form. At least, that is the idea that he is showing there. Which is different from what Akula's scope shot is showing. Yet, both ways may work.    You can see from my videos, as well as Stalker's videos, that the two waves forms don't cancel each other out to 0, as you suppose. The HV wave is supposed to interrupt (to stop), by a slight delay, the push pull's pulse. But, they don't cancel out, as you are supposing. Nor is the HV circuit supposed to be "adding" it's voltage to the push/pull circuit's output, either. As the HV pulse, is an interruptor circuit. This IS it's "fundamental knowledge" or mode of operations, etz... Which I have commented on many times, in my past 4000 plus posts. But, just how all this is actually supposed to work, is still a mystery to be proven, for now.
NickZ
Quote from: Raycathode on April 18, 2020, 03:50:48 AM
No look again at Nelsons circuit he kindly published he is using that !
Want to try again ?
  Raycathode:  Which one of Nelson's circuits are you referring to?
     NickZ
AlienGrey
Well if you made Nelsons circuit you could use your scope to see how a real device works
if you run the katcher and put your scope across (with a times 100 probe)  or close to it the inductor or grenade winding
with out the push pull working what frequency do you get out ? you need to find this out.
Stalker never shows any device working as i have ever seen
