0 Members and 355 Guests are viewing this topic.
Raycathode
Quote from: NickZ on April 23, 2020, 11:22:11 AM
   Dave:   Are you asking these questions because you are interested in building such a device? Or is this also for just an educational point of view.  T-1000 has answered me when I ask him something. But, he can tell you what has been said. He has not built up this device, and therefore has not practiced what he mentions. But, in any case he is helping to translate what he sees in the videos.
   And yes, my grenade does get hot at times. Doesn't the same thing happen to normal running transformers, when running on several hundred watts?
   The normal Kacher output running frequency at the antenna coil is from about 850KHz to about 2MHz, or so. With a voltage of around 3000v, to 10.000v. Mine runs at around 1MHz, and that can be adjusted up or down in frequency by simply adding or removing wire turns.
   The idea of now using controllable Kacher circuits, to pin down the exact sync to the grenade/yoke circuit, is what some guys are up to. Along with the idea of causing a delay in the pulses. But, this all still needs to be studied, and replicated to show IF there is something beneficial to that, or not.  As the grenade/yoke TL494 circuit is performing no magic by itself, and needs a Kacher HV pulse to sync with. Also, is needed a long thick 37.5m to 40m ground line which both circuits are connected to.
   Making both the induction circuits, along with a controllable Kacher circuit, is not easy. It takes much time and money.
Needed is also a scope, variable power supplies, along with a 24v feed back PS, signal generator, spectrum analyzer, a 40m ground line, many components, 200w to 1000w bulbs, and a lot of wire for the coils. Just for education purposes... cause it may not work, as expected, after all. So, this device is not for the faint of heart.
  Here is an image of what my device looks like, at this time:
Nice looking bit of kit you have to work on.
Raymondo
ps i think i have a 40 meter band trancever some where havent used it for about 20 years ;)
NickZ
   Yes, well you might need it in the near future. If the internet gets hacked...banks and ATM close, no work, no jobs, etz...
   I'm ready as I will ever be, right now. Bring it on...  get it over with.  Oh, wait... No not yet... no OU device.  OH no...
   Sorry but, like Nelson once said,  "I make a little funny with friends".
Good morning (4:55 am here),without incommodation,
when some enter in search machine/-s ,not with "transce-ver" but " EU Eureka transceiver" what you think you will get ?
An "L'OM'BARDI"- engine ?
Sincerely
OCWL
conico
Hello friends,
All Ruslan devices have the same mode of operation. Ruslan talks a lot but does not say what is important.
We need to have two different signals, one on the Grenade coil and one on the inductor.
The two signals must be 10-90 degrees offset from each other, on the inductor the frequency must be double the frequency of the signal from the Grenade coil
Watch Soliman's post on page 1446, he says the same thing.
I have a document that was translated by google. We need a better translation and translation of what is written in the pictures in this document.
