0 Members and 1216 Guests are viewing this topic.
NickZ
   As the load of bulbs also becomes a working part of the circuit, it's important to test the output to the input with a load of a few hundred watts. Along with the right ground line, as well.Once a feed back circuit is connected up, we can see IF the system will self sustain itself, or not. As this loop takes a lot of juice to operate, also.
soliman
NickZ
try to do my setting and then we can comment on it. please
conico
Soliman,
I have some noise in Push-pull.
What kind of snubber did you use, just like in the photo below?
Raycathode
Hi Mr Conico I don't use that type of snubbing it wastes energy and produces execs heat, I use 2 diodes of the drains with a cap and a resister back into the supply but why not bifilar wind the centre tap ( the 12 BNT winding )-( drain - power in - drain) that way it gets absorbed by the core and you don't get the ringing.
PS
While your on is your Tesla Katcher coil the self oscillating coil circuit, do you have trouble getting it to oscillate with a reduced winding on the long primary winding ? only the drive transistor ends up with a reduced rail to rail swing ! but there is a way round that problem.###
Regards Raymondo
conico
Hi!
''bifilar wind the centre tap ( the 12 BNT winding )-( drain - power in - drain) that way it gets absorbed by the core and you don't get the ringing.''
Can you make a drawing on that winding?
For Soliman,
Duty cycle 28% , frequnecy 16.9-17 Khz, 244Vpp and 7 Amps  from PSU on the little movie
What's next?
