0 Members and 117 Guests are viewing this topic.
Raycathode
Quote from: conico on May 02, 2020, 04:55:06 AM
Soliman,
This is the most important information for don't have noise in system. Thank you!
Until now, I start Katcher and duty-cycle jump from 20% to 39-40% and frequency jump from 8.44Khz to 16.9Khz, exactly what Soliman said.
If you want a video, tell me because I want to disassemble the Push-pull to reach pin 4 of the TL494.
Hi Conico and Soliman
I'm trying to my head around whats going on here,  What type of Katcher circuit are you running ?
Haw are you altering the duiy cycle of it ?
Any chance you can do that video it might help, cheers
Raymondo
conico
My Katcher is the simple one with 2SC5200, not a controllable one.
Ok , i'll make the video in 30,40 minutes.
I'm not '' altering the duty cycle'', the noise do that, you will see.
NickZ
   The duty cycle or frequency on the Kacher is NOT changing.
It's the induction circuit that changes. But, why is the initial setting on the induction circuit starting at only 8KHz, instead of the normal 15 to 19Khz?    Ok, so the noise is gone.  And... what results happen? Now you have more power, with less input? Or not?
   What is the benefit of this, besides the noise?
   Waiting for your video...
conico
The noise from tesla coil change duty C and frequency to in Push-pull, look:
You can try to connect only Katcher to the PSU and Push-pull to be disconnected from the PSU.
You will find the Katcher signal everywhere with the oscilloscope.
GeoFusion
Hi all :)
Hope you guys are doing well.
Some new Updates on the bench after a while;
https://www.youtube.com/watch?v=vTCaF7R4Z-M
All, if you are using simple kacher, I want to state that a fast switch ( mosfet) is needed on the negative leg of kacher circuit
this allows for short burst. It is needed for what we all are aiming for.
Nick, take a look and I have enough light installed now around so to see almost everything on the bench. =)
Soliman, hmm Impressive, does gives like a clean signal then.
Conico, it looks like when you activate the switch it jumps from 8Khz to 17Khz.
that is only the kacher? hmmm should not influence like that but ok.
         Cheers~
