0 Members and 529 Guests are viewing this topic.
conico
Quote from: NickZ on May 02, 2020, 08:56:00 AM
   The duty cycle or frequency on the Kacher is NOT changing.
It's the induction circuit that changes. But, why is the initial setting on the induction circuit starting at only 8KHz, instead of the normal 15 to 19Khz?    Ok, so the noise is gone.  And... what results happen? Now you have more power, with less input? Or not?
   What is the benefit of this, besides the noise?
   Waiting for your video...
It is a very big problem with the noise.
Start katcher and disconnect power from push-pull. You wil find 1,1Mhz in the gates of mosfets and if you start push-pull you will have a big duty-cycle so, push Pull will give more energy on light bulbs on the load, but is not the effect we are looking for.
It is just a hoax, when you start katcher will be more lights on the bulbs.
NickZ
Quote from: conico on May 02, 2020, 10:25:29 AM
   I don't understand, "It is just a hoax"?   I don't have a big problem with noise, and the 1.1MHz from the Kacher runs all through the induction circuit, as I have shown in my last posted video. Not just on the Fets. And of course there can be more power going to the bulbs when the Kacher is on. But, that does not mean that there is OU. Big difference...
conico
yes, my system is just a hoax. I'll see what happens when I will eliminate that noise.
When you start Katcher push pull will take power from PSU and delliverate to the load bulbs.
NickZ
   conico:   Ok, well I still don't know what you are trying to say. Just don't get fooled by brighter bulbs, without knowing the output power.
   Anyways, here is a new video by Geofusion. He posted it on the partnered coil thread, perhaps he meant to place it here.
   So, I hope that it's ok to repost it here.   https://youtu.be/vTCaF7R4Z-M
   PS. Geo, you know that if you connect that HV Kacher with that much power to the induction circuits, it will blow something up, real quick.  Remember that Ruslan said, that the Kacher does not need to be strong, it's purpose is to disrupt the flow of the induction circuit, not blow it up. Or am I wrong? I don't want to see that happen. Just be careful, that's all.   Previously I also connected the 28t coil's output through filters, and full bridge rectifier, to the Kacher's input. But, you have to lower the voltage going to the kacher, or else.
T-1000
Quote from: NickZ on May 02, 2020, 12:23:39 PM
Hi Nick,
As for katcher this can be used - https://i.imgur.com/c04yYgj.png
The second important thing is power interrupter which turns katcher ON at the right moments.
This makes FM modulation for Radio Moscow.
Also depending on how far you are from Earth lay lines the voltage needed to ionise air is needed to be higher the more far you are from it.
Cheers!
