0 Members and 332 Guests are viewing this topic.
Сергей В.
Some GOOD NEWS !!
Dally have made another Solid-State-OU-Generator. He still waiting Chinese oscillograph. It's seems to me that Chinesse don't like to sell digital oscillographes  to Russian people.
The same as Americans. Interestingly almost all High-Tech Digital Oscillographs which are on auctions on Ebay don't sell to Russian people. If you don't belive me check youself. NO DELIVERY OF SUCH EQUIPMENT TO RUSSIA. Coonclusions make yourself !! I will not use "SHARP WORDS" for now !!
Second GOOD NEWS is this. Finally WE know The Secret of Stanley Meyer's water fuel cell. Now it's time to be revealed. The Secret is Nano-Pulser. Yes, he had used High-Energy sharp nano-pulses to separate water on Hydrogen and Oxigen in his water fuel cell. Unfortunately for him and all humankind American secret services had killed him and stop his genious production of Hydrogen and Oxigen to be spreaded over the world. Calculate how many toxic gases went to our atmosphere for last more than 20 years. Then calculat how many human lifes were lost in OIL BARONS WARS for oil production and how many people were died for presence of hard metals in their vital organs??
So my suggestion to members od this forum is very simple and reasonable. When next time some trolls wherever from which country they are, talk rubish, ask them about above present facts and shout-up their vile mouths for all times.
Look at last picture and tell me what did you seeing. In fact not me by tell the others to see and wake-up !! Maybe next chance will not be !! The Destiny is in hands all of us. Think about !!
http://www.liveinternet.ru/users/edward_lee
d3x0r
Quote from: d3x0r on October 03, 2012, 05:37:06 AM
but I was clearly reading 75V on the capacitor across L4 (when L2 was at resonance)
I was wrong, with just that green coil I was only able to get to 50 volts... which would be like the induction of L1 + L2 on L4
verpies
Very good info on the Russian parts!  Thank you.
Quote from: Сергей Ð'. on October 03, 2012, 11:42:41 AM
For Ð"УН (VCO) use 74AC00PC and for Ð"НСИ (Nano-Pulser) КР1533ЛА3.
Does the КР1533ЛА3 Quad NAND Gate  belong to the 74ALS... family?
Why is it necessary to mix different logic families? AC and ALS ?
To make several kV Nano-Pulser pulses use several diodes serially. Ferrite ring i think you can find easy. You may use bigger ring up to 2 cm outer diameter.  М6000НМ or better.
Ferrite is going hot so must be sealed or glued on KT926 radiator. And connecting wires must be as short as possible if you want nano pulses !! For Ferrite ring use quality teflon wire or wire which isolation can handle more than 200 degrees temperaure. This is important coz Ferrite ring, Transistor and DSRD will running continuously. Use good radiator for DSRD diode!!
What do you think of the transformerless method of driving the DSR diode, like shown on the diagram below? I can get 800ps 320V pulse with 12VDC power supply.
Vortex1
From Hoppy:
QuoteIntuition tells me its a fake but I am prepared and want to prove that the device is genuine.
Yes, I feel the same way because my intuition has failed me a few times.
BTW The document I uploaded earlier tells of the use of the lowly 1n5408 rectifier as a DSRD in the section entitled "Experimental Results".
verpies; I like it very much. Can you post a few values on the schematic?
Hoppy
ПривеÑ, всем !!
I found our Russian parts on Ebay.com
RUSSIAN DSRD diode KD206A
http://www.ebay.com/itm/KD206A-USSR-RUSSIAN-RECTIFIER-DIODES-LOT-OF-50-NEW-/220683918392?pt=LH_DefaultDomain_0&hash=item3361c95c38
$38.50/50=0.77$ per part
RUSSIAN DSRD diode KD226G Rectifier Diode 600V 1.7A NOS
http://www.ebay.com/itm/100-PCS-KD226G-Rectifier-Diode-600V-1-7A-NOS-/251057009269?pt=LH_DefaultDomain_0&hash=item3a7429f275
US $5.50
MILITARY GRADE RUSSIAN AVALANCHE Rectifier DIODE DL171-320-14 320A 1400V 1,4kV
http://www.ebay.com/itm/MILITARY-GRADE-Soviet-AVALANCHE-Rectifier-DIODE-DL171-320-14-320A-1400V-1-4kV-/250979935248?pt=LH_DefaultDomain_0&hash=item3a6f91e410
US $59.99
RUSSIAN-MILITARY-KT926B-KT926-SILICON-PNP-TRANSISTOR
http://www.ebay.com/itm/RUSSIAN-MILITARY-KT926B-KT926-SILICON-PNP-TRANSISTOR-7pcs-all-1991y-/350603040082?pt=LH_DefaultDomain_0&hash=item51a191d552
RUSSIAN MILITARY KT926B
US $17.00
RUSSIAN-KR1533LA3 = 74ALS00 ( 74 ALS 00 )
http://www.ebay.com/itm/New-3-pcs-x-KR1533LA3-74ALS00-74-ALS-00-1533-3-/190598741118?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D2475968235941317723%26pid%3D100033%26prg%3D1011%26rk%3D1%26sd%3D190598741118%26
US $1.89
Thanks for the info. A couple of points: The KT926 transistor is shown incorrectly as PNP. It is as far as I can tell from spec, an NPN. Where did you find out that the KD226G is DSRD?
Hoppy
