0 Members and 143 Guests are viewing this topic.
conico
''AlienGrey''
Can you post ''show'' a diagram of your Katcher?
thank you!
AlienGrey
Quote from: conico on May 17, 2020, 05:46:23 AM
''AlienGrey''
thank you!
Hi Conico, It was some years ago I did this possably 2015 the circuit would have been the Akula device
but i intergrated the IR2110 it was easier and i had a few of them bto hand.
The board does work but the device uses self oscilation katcher winding feed back.
also a puse aligning circuit was added re geo posting. Note the 50k width pot is too big
i used a 10k in the end.
soliman
Quote from: soliman on April 30, 2020, 03:49:06 PM
Hi.
how to make RM (radio moscow) without noise:
1-use only the 28-turn coil (the 4-turn coil leaves it disconnected for now)
   connect it in series as is common with the grenade. Here look for the resonant frequency
   The more voltage it delivers with the lower consumption of the power source.
   write down this frequency. in my case it was 18.51Khz duty cycle about 35%
2-move the frequency to half the resonant frequency, in my case it is 9.55Khz
move duty cycle to 22.4%
3-turn on the kacher and move the face up to interact with the system.
  solpresa. what happened to me. the frequency jumped up to 18.51Khz the duty cycle was up to 44.8%
  even more one of the gate mosfet is removed.
4- I would like you to do this and tell me your experience with this matter.
    You. It will have a powerful system, but the most important is that it has no noise.
5- oh, and at the end connect some small capacitor on the 4-turn coil
   and this will give you more power with the correct capacitor.
   the capacitor you use is 0.33uf 2000Volt WIMA.
   then in the 4 laps I put 2 * 0.15uf 2000Volt WIMA in series.
6- this is very powerful and has no noise.
7- End.
hello everyone,
In one of my last post, 1462. I explained how the frequency jumped
double and thus the duty cycle.
I found that pin 13 of the tl494 has three functions:
OUTPUT CTRL pin 13
Selects single-ended / parallel output or push-pull operation.
and that is why the frequency jumps twice, if you.
drops too low at a voltage that reaches that point it becomes
single-ended mode.
These pins 3 and 4 can be very sensitive to you. You can still make it jump even by bringing your finger closer.
but this is not dangerous because the kacher is off.
Thank you.
AlienGrey
Yes that is true regarding pin 3-4 this can also be used as AM modulation
Since GeoFusion posted his last i was looking at his very interesting video
if you look at the katcher his tap is 3/4 the way a long a sort of 1/4 wave.
AG
soliman
Hello guys,
This information could be useful for those who still have a weak kacher.
I have noticed that my kacher was very weak even if I used 24volt
  or 60volt and even more 130volt. the result was always the same,
had no interaction with the earth.
but what I did:
change the line transformer that some kacher circuits don't use and put in a 30mH transformer and now I have a powerful
kacher and I have interaction with the earth. uff this is scary
I have a long spar gap almost more than an inch.
I want to note that I am using a controlled kacher(akula).
and 130 volt.
Thank you.
