0 Members and 924 Guests are viewing this topic.
NickZ
   And I want to note, that the 1 inch streamer will burn out your induction circuit, and anything else that it touches.   Some guys think that it's important to have a strong Kacher, but it's not. The Kacher needs to be tuned to the right frequency, that is what is more important. If a delay is really needed or not, is to be tested. But, the main thing is the proper sync.
soliman
Quote from: NickZ on May 17, 2020, 10:51:49 AM
   And I want to note, that the 1 inch streamer will burn out your induction circuit, and anything else that it touches.   Some guys think that it's important to have a strong Kacher, but it's not. The Kacher needs to be tune to the right frequency, that is what is more important. If a delay is really needed or not, is to be tested. But, the main thing is the sync.
[/quote
Hi, NickZ
[font='verdana,arial,helvetica,sans-serif']Could you give me a hand on how to tune the kacher or where I can find such information.?
Thank you.
[/font]
soliman
Hi, NickZ
Could you give me a hand, on how to tune the kacher or where I can find such information.?
Thank you
soliman
Hi, nickZ
The kacher, maybe it should not be so powerful, but one thing must be clear and that is that it needs to interact with the earth.
and the only way that I have been able to find interactive with the earth so far is using this line transformer.
I appreciate any comments.
Thank you.
NickZ
   The Kacher needs to interact with the induction circuit, first, not to the ground. The ground will help it, but the tuning is done to the kacher by removing wire turns on the kacher's secondary coil. It needs to be tuned to around 1.5MHz, or so, with the 37.5m ground line connected to both the induction circuit, as well as the ground. That can be a starting point. You can tune it by controlling the frequency setting on the TL494 but, it will not provide the same output at the proper frequency. The higher the frequency, the lower the output will be, but it needs to match the induction circuits. That is the point.  Look at the size of Ruslan's Kacher secondary coil, or Akulas. Not Adrians or someone elses.
  That will be close to what you need to follow and replicate. But, more fine tuning will still be necessary, afterwards.
So, first set up the Kacher to run at around 1.5MHz, and then go from there. If you mix and match using other peoples specs, you'll be confused, as they may have a different set up, needing different frequencies.
   I am following the Stalker schematics, below, which is Stalkers match up and sync, 16.5KHz for the induction circuits, to 1.5MHz for the Kacher. Which is also similar to Ruslan's specs, which are also similar to Akulas second self runner, as they all were replications of Akulas second device.
  You may find that there is no match where we assume that it should be by doing the math.  It never is...but it may be found somewhere close to it.   The choke which you are calling a "line transformer" is very important. And can also burn up if it receives too high an input current. As, it is placed there to protect and control the input current. If that choke gets too hot, it may not be the right value, or your input is too high.  And, if it has too thick a wire on it, and so does not get too hot, that can also cause problems to the rest of the kacher circuit components, as it's not doing it's job.
    NickZ
