0 Members and 357 Guests are viewing this topic.
soliman
Quote from: conico on May 18, 2020, 08:31:07 AM
Mine is the same 1 inch /1 inch with 15 +15 turns 0.75 mm wire.
I measured the inductance is 50 uH (microHenry) on one part and 50 uH on the other.
hello, conico, in my case I dealt with several transformers and they did not work, but when I went to several milihenry the thing was different
And now I'm going for more miliHenry, to see the effect that happens.
core size is not that important.
the important thing is how much it measures.
good luck.
NickZ
Quote from: Raycathode on May 18, 2020, 04:47:23 AM
Conico & Soliman, where about is it you have of had this choke in the circuit ?
Re comparing Geo's katcher with Nick's device,  Nick's device is about 1/3 the
Size of Geo's
It's interesting the resonating 'racket' Geo's device makes, is Nick's device doing the same thing ?
But the scope shot is nothing like it, it's somewhat confusing.
Is it the actual frequency the coil is at ?
or is it the way the 'interrupter is affecting the pulse or beat ?
Can any one comment ?  Geo ?
Here are some scope shots I found back in time on this thread.
Nick's are a bit different to thease
From an educational point of view Help me out here !
R C
Ray:
   Of course the two different types of Kacher circuits are different, and their signals are different also. But, the main thing is, how well they will work produce a self runner? As so far, neither circuit will do so. Nor anyone elses.
   I have not seen any of the controllable kacher circuits actually work better, than my simple kacher circuit, as yet. Whatever effect the controllable circuit produces, I can do the same, or better.  So, I'm still waiting to see any real improvements, after all these years, by these much more complicated Kacher circuits, compared to what I can do. And yes, the RM sound is similar on both types. The ringing is not at the same frequency as what the scope says. As you can't hear a sound at 1.5 to 1.8MHz.
   I think that possibly the ringing RM sound must be sounding off at a harmonic (KHz range) of the set Kacher running frequency in the MHz range. Or a harmonic of the induction circuit's frequency. That sound is usually an indication of interaction, as without it, I don't see any interaction, nor any additional  effects at the output.
soliman
Quote from: NickZ on May 17, 2020, 12:06:16 PM
   The Kacher needs to interact with the induction circuit, first, not to the ground. The ground will help it, but the tuning is done to the kacher by removing wire turns on the kacher's secondary coil. It needs to be tuned to around 1.5MHz, or so, with the 37.5m ground line connected to both the induction circuit, as well as the ground. That can be a starting point. You can tune it by controlling the frequency setting on the TL494 but, it will not provide the same output at the proper frequency. The higher the frequency, the lower the output will be, but it needs to match the induction circuits. That is the point.  Look at the size of Ruslan's Kacher secondary coil, or Akulas. Not Adrians or someone elses.
  That will be close to what you need to follow and replicate. But, more fine tuning will still be necessary, afterwards.
So, first set up the Kacher to run at around 1.5MHz, and then go from there. If you mix and match using other peoples specs, you'll be confused, as they may have a different set up, needing different frequencies.
   I am following the Stalker schematics, below, which is Stalkers match up and sync, 16.5KHz for the induction circuits, to 1.5MHz for the Kacher. Which is also similar to Ruslan's specs, which are also similar to Akulas second self runner, as they all were replications of Akulas second device.
  You may find that there is no match where we assume that it should be by doing the math.  It never is...but it may be found somewhere close to it.   The choke which you are calling a "line transformer" is very important. And can also burn up if it receives too high an input current. As, it is placed there to protect and control the input current. If that choke gets too hot, it may not be the right value, or your input is too high.  And, if it has too thick a wire on it, and so does not get too hot, that can also cause problems to the rest of the kacher circuit components, as it's not doing it's job.
    NickZ
hi nickZ
I already have something like these waveforms, but it is out of sync. it cannot be stabilized with the oscilloscope
how do you think What could be synchronized?
I also want to tell you that the frequency of the kacher is within that pulse seen there.
you can see it when you expand it.
AlienGrey
Quote from: soliman on May 18, 2020, 07:57:01 PM
hi nickZ
are you talking about the sine wave, the free running circuit ?
soliman
Quote from: AlienGrey on May 18, 2020, 08:20:18 PM
yes, you are correct. AG.
the sinewave is calm but the pulse moves randomly
look at the post of nickz 1469
  Re: Kapanadze Cousin - DALLY FREE ENERGY
Reply # 22029 on: May 17, 2020, 06:06:16 PM.
Stalker's scope shot.jpg (374.56 kB, 1200x675 -
