0 Members and 250 Guests are viewing this topic.
conico
Inductor and coil grenades have a grounded terminal each. Extra energy, I think it comes from the ground.
the inductor has a capacitor in series, this means low voltages and many amps 10-20 amps, when it resonates.
Grenade coil has a capacitor in parallel, which means high voltages and low current, when it resonates.
when you start Katcher high amps and high voltages go on load.
all these signals must be synchronized.
I think Soliman finished the system, he didn't ask about synchronization or anything else.
Doh-Boy
1472 pages - Wow !! how much time and money I wonder ? on what (just saying) -- IMHO is a gang of  tricksters. I'd like to think I'm wrong but alas. remember this tosh?
https://youtu.be/3urK7ybyyZM
well allow me to enlighten you a little bit regarding European electric systems – Neutral .is Ground and visa versa . The centre tap of the supply transformer is grounded. In most systems the neutral and earth are also bonded at every joint  it used to be called PME - (protective multiple earthing) Providing the earth connection is good it can carry the return current – as its doing here. It will have no voltage , It should be no surprise to anyone  that part of this circus act is one of the clowns sticking his tongue on the wire. Why not its zero potential – Its ground! notice great care is taken over that ground connection were that to be lose or intermittent the circus would need a new clown - that one would be dead as a hammer!
That bare cable is carrying current of course however the troupe want you to believe the current is being extracted from the ground – alas I'm afraid not folks! Its the other way around. in fact under that concrete that earth rod could very well be bonded very solidly to neutural .- (It would be if that was my tounge  going anywhere near this cruel farce)
where then is the mains live feed into this shambles ? Through the wall and into a leg of the fan , even that's shoddy work – here's a couple of screen shot -stills I took for you to see - The arrow marks the live feed cable input to the abortion . find the arrow -- clue its bottom left pointing at the mains input cable!
http://dnp.s3-eu-west-1.amazonaws.com/a/TK%201.png
http://dnp.s3-eu-west-1.amazonaws.com/a/TK%202.png
why did I look there? Most of ny working life has been spent as an electrician and EE – If I were to play this hoax I would have sneaked the feed in through the wall too –( through a solid concrete floor is difficult and hard to conceal .) I'd like to think I would have done it better than this group of renegades . To drill at a sharp angle through the floor and excavate a little bit outside would have hidden the feeder better! Shoddy work even for a trick!
The last bit of bull shit with the nine volt battery cobblers ? – Its called a latching relay nothing very clever .might look good if your particularly gullible.
Why then would these people go out of their way to produce such a farce ? Simple – Money , That connections not difficult to make either . There are OU devices but I think you'll find this hands around the world stuff - is a red herring.  who pays for that and why is another subject but its - big oil connected. If you wish to research that area Anthony Craddock - is a good starting point! OU is a great hobby but please take care - Its not full of smoke and mirrors without good reason. I hate seeing honest researchers being tricked.
kindest regards Duncan
Doh-Boy
  anyway back to Covid 19 for the moment - more serious world changing in fact . Kindest regards Duncan
conico
You may not know it, but for more than 20 years in Europe, null on the grid has not corresponded to ground.
If there is a small potential difference between null and ground the greed is automatically disconnected for protection.
It is a circuit breaker relay circuit breaker that disconnects the power from the socket automatically to protect people.
so it's not what you think.
All those who succeeded in the systems, filmed in the field or in the forest where there is no electrical network
Doh-Boy
It is earth leakage protection you are considering - it is very easy to wire around that - in fact even in domestic and industrial situations certain circuits MUST NOT be connected via earth leakage certain parts of fire alarm systems (for instance) also escape systems for invalids  ect -  so yes part of your comment is true . (were it a socket outlet for instance) however you can clearly see the trickery here so why continue with any of this farce ?
Its OK to be fooled I guess we all have especially in the area of FE with so much smoke and mirrors at every turn.  However  once its flagged by someone - Its time to take care surly. If you have one of these things running in your local forest I'd love to come and see it -- however if its taking the best part of 1500 pages to emerge and hold centre stage-- Its quite some expensive wounds folks have to lick .
There are systems that work I suggest this isn't one of them . However like all of us you must follow your own path - I have flagged - posted and pointed at the corruption(with big arrows) -- I could draw the rest of the bull too but I'm sure you know how a latching relay works for you interest here is a typical EU grid set up - particularly notice the solid connection neutal to earth at the distribution board --- ergo N and E are bonded one and the same and so AT ZERO VOLTS ergo ground--- I hope thats clear enough to most.
https://www.epanorama.net/documents/groundloop/feed_1phase.gif
good luck either way I simply warn and flag up a scam on this occasion . having spotted one I wont be having anything more to do with this particular TK led circus troupe! I can't afford to waste time and money like that I don't mean to upset - but you can have all my share of this particular joke.
Here's chapter and verse on grounding and PME if anyone really doesn't take my word
https://www.epanorama.net/documents/groundloop/electrical_wiring.html
The electrical regulations across Europe are ' harmonised' – so substantially all the same which is why its easy to see through this skit .
I really don't want you guys wasting lots of money time and energy on a belly laugh for this gang . I've done it myself more times than I care to think about. I'd really like to be wrong - but I think not.
my Kindest regards Duncan
