0 Members and 62 Guests are viewing this topic.
conico
NickZ, You said:
''  And yes, I've burnt up many many things over the years. But, my Kacher works ok now, as I've shown on my videos. And it can even partially light a 100w incandescent bulb, or a couple of 50 watt bulbs, fairly brightly. I did blow a 10 watt bulb with it though.''
Did you use 18v or 24v?
how many amps from the PSU did you have for supply Katcher?
did you use ground line?
NickZ
Quote from: conico on June 01, 2020, 04:37:06 AM
   I use a 24v, 10 amp PS.  When I use this PS for the feed back circuit, I use two 12v, 7ah batteries for the input. I don't know for sure just how many amps the Kacher uses just by itself. But, normally about 2 amps. I also use an 18v 2 amp PS for the Kacher, connected to an outside 37.5 meter ground line on the transistor emitter. I've never had my Kacher not work, even if I don't use a choke, or with different chokes. But, the transistor can get hot at times, or the winding can burn on the thin wire wound ones, like I showed in the image of the three chokes.
   Ray: That video from Adrian got cut off right at the most important part, where he is showing what the induction circuit that he used looks like. It is the same as my push-pull circuit. Same as Stalkers, same as Ruslan 7.
conico
18v X 2amps = 36W or  24V X 2,5amps = 60W this is the power in and the result was 100w bulb?
it could have been overunity?
by the way, there are 4 chokes in your image, not 3.
NickZ
   No. No OU. I can light a 250w mercury vapor bulb with the Kacher, but it doesn't light 100%. That is why I always say "partially lighting" a 100w bulb, or two 50w bulbs. There is no self running or OU by just using a Kacher. Unless...   Unless you are Poma, or Roma. IF, it really works, he is a magician.
conico
Are you sure it was not overunity?
Look at page 1471 at my diagram.
It's a katcher, Tesla coil, antenna,  Hooper bifilar, a light bulb and the ground line, you had the same, only the inductor is  tesla bifilar.
About Poma device , i work for this  to.
there are two tesla coils and only one Katcher. Let's say the first coil works at 3x frequency and the second one has to work at x frequency, the two signals combine and hit the load. No ground required.
