0 Members and 105 Guests are viewing this topic.
Grumage
Quote from: NickZ on August 23, 2013, 01:06:00 PM
  So Grum, the first thing may be to get something made of iron to heat up in the big air coil. And if it does not heat up, then, make a separate coil of thick copper wire, made to test the induction heater type output.
  Then the next thing is to get the big air coil's inner choke to help raise the voltage back up to 110- 220volts Ac or higher, but with lots of amps.  Easier said than done...
Dear Nick.
I can raise stupidly high voltages on the choke at the resonant frequency. I have a 10 turn pickup coil on the choke who's turns are 255. I am using the probe on X100 and with the scope on it's max 5V/cm, the sine wave goes off the scale. But this is just volts little current.
The device just sits on the bench now. I have tried everything?? Divine intervention is the only thing left!! :) :) :) That or a VERY large hammer!!
Cheers Grum.
NickZ
  Yes, I understand. My set up is doing about the same thing. But, lets not give up, yet.
Let's make the oscillator coils induction heater work, as the first step.
If you recall that's the route that Akula took, and Igor is going in the same direction.
  If this OU effect were easy it would have been found out about long ago.
MenofFather
Quote from: Grumage on August 23, 2013, 12:19:23 PM
The large Yellow tube is a Tesla secondary of 1000 turns of 0.25 wire on a 40 mm dia former. I am getting to know some Russian?? Please correct me if I am wrong?? :)
Yes, you right. Yelow is wound on 4 centimeters diameter tube 1000 turns with 0.25 milimeters diameter wire emulated, like in Tesla coil.
MenofFather
Quote from: magpwr on August 23, 2013, 04:55:50 AM
Hi everyone,
Base on the attachment which i have pointed.Can anyone advise me if by using HV from flyback transformer to the thick coil as shown in diagram.
Would this thick coil will be acting like a induction heater if a metal is placed in it.My question is would the metal eg:screwdriver get hot like those that we see in induction coil.But only this time it's a HV but low current source.
"[size=78%]Would this thick coil will be acting like a induction heater" [/size]
[size=78%]Brown coil i belive, that not acting like inductor heater.[/size]
[size=78%]
[/size]
gyulasun
Dear magpwr.
Hi Grumage,
Sorry that I did not notice your above answer to magpwr and I answered quasi the same to him in my Reply#2213, just after your reply...  IT appeared to me that nobody has answered his question till my post.
greetings,  Gyula
