0 Members and 440 Guests are viewing this topic.
NickZ
   You did not specify that those were the grenade and inductor SELF resonant points. And not the running frequencies.
    The question was, what are his running frequencies? Which is what we have to the tune the device to. How would he know just what the open self resonant coil frequencies are, if he didn't even have a scope at that point. Just to calculate the frequency by math, is not enough, in this case. Besides that connecting the long ground line will change the running frequencies.
  We know that the 28t coil goes to a 37.5 or 40m coil. What that combined frequency is, is what the question is.
   If you know me, you would know that I'm not here to spam. I hope that you realize that. As Geo and I are the only ones left here with a full working replication, which we have both put in a lot of time to crack this nut. Even if they don't self run, as yet.
   I'm here working on the truth, not BS.   And yes, I can read, you're disrespectful post, very clearly.
WhatIsIt
Quote from: NickZ on June 05, 2020, 10:01:20 AM
  We know that the 28t coil goes to a 37.5 or 40m coil. What that combines frequency is, is what the question is.
   If you know me, even just a little, you would know that I'm not here to spam. I hope that you realize that. As Geo and I are the only ones left here with a full working replication. Even if they don't self run, as yet.
From my post:
"If I understood Adrian correctly, grenade 6,8Mhz, inductor 3,4Mhz resonant point.
Ratio is 2:1."
Over the years of research, you should know by now that resonant points does not mean always working frequency.
Adrian also mentioned 37,5m. But I leave to you to translate videos for yourself,
because, every time when I post something, you come and spam, like a child,
without even trying to understand what I am writing.
conico
I saw Adrian's movie again. He says 6 and 8 meaning 68Khz and 3 and 4 meaning 34khz.
Push-pull works between 8 and 72 khz.
in my system I tried 34Khz but I also have grenades  34Khz and inductor 34Khz and 34Khz push-pull to.
If I tried 68Khz in push-pull ,everywere it was 68 Khz.
I can't have different frequencies in grenade and inductor.
This tells me that there must be a phase shift between the grenade and inductor signals. Exactly what I said a few pages back, otherwise there can be no effect.
I found this phase shift at Akula, at Alexeev and Dinester confirms this.
Kapanadze suggests a coil at 90 degrees, it is the same with a phase shift of 90 degrees.
In my system there is a phase shift of 3-5 degrees between grenade signal and inductor signal, is not enough, it must be 30-90 degrees.
NickZ
   WhatIsIt:
   It's not my fault that you are not clear, and keep being disrespectful.
   Conico:  You can get the different frequencies between the inductor and 28t/grenade output coil by using different value tuning caps. But, that will all change when you connect a full bridge rectifier and feed back circuit, proper ground line, etz... So, the system needs to be tuned by having all those components in place. As well as connecting the earth ground to the Kacher, and to the grenade.
conico
I tried everything, with ground and bridge rectifier and different bulbs on load, just 3-5 degrees phase shift between signals.
Have you tried in your system, do you have a phase shift between signals?
