0 Members and 409 Guests are viewing this topic.
NickZ
   conico:
   I really can't remember concerning a phase shift.  I think so, but I was not specifically tuning for a phase shift, but for best sync, instead, between just the induction circuits. And those coils have all been made to the specs. And, also which of the tuning caps on both induction circuits provide for the best output at the load of several hundred watts. Regardless of where we think that the sync should be, by doing the math. As that calculated resonance point by math, has not worked out for me, in practice.
  One of my shortcomings is, that I don't have a varied selection of those very expensive WIMA caps to tune with. And when using lower voltage caps we can be losing some of the valuable HV gains. Which may only to be found if using those WIMA 2000v capacitors, instead of those cheaper lower voltage caps. As I am dealing with Kacher voltages of at least 5000v. And I have blown even the 2000v caps, on the output series circuit.
So, I think that this is where and what I need to work on. But, it's very expensive having to use only the right wima capacitors for the job, just to see which ones work best. That's why accurate schematics with all the proper voltage and frequency test points is crucial for success.
conico
NickZ
  The 2000v Wima caps 0.47 tell me what a  few of those will costs...
conico
470Nf = 0,47uF at 2000v is 3.2 US dollars it works at 700v AC. If you buy 5 it will be 2.92 dollars / piece
470Nf or 0,47uf at 1600v is 1 dollar and a half, it works at 650v AC
AlienGrey
Quote from: conico on June 05, 2020, 02:50:55 PM
So lets stick to basics, whats the inductoance of the Grenade inductance winding ? lets say its about 159 micro henrys and you are using
a 470 Nano Farad cap in series so whats its resonant frequency ? 3mhz I don't think so as the TL494 has a maximum frequency of abot 500khz.
AG
