0 Members and 49 Guests are viewing this topic.
NickZ
   Guys:
   The theory of operation for the TK, Akula, Stalker, Adrian, type of devices has been presented and repeated many times, and yet still no one can come of with a working replication. WHY? Do we really need to keep repeating it? Has it not sunk in yet?
   I think that I am very close to how Ruslan, Stalker, and Adrian did it. But, also think that my sync is not perfect. I do need the right type of tuning caps, as each device is built a little differently. With different yokes, wires, caps, diode bridges, load types, etz... So, where do I go from here. Well perhaps to obtain the needed caps, firstly. Yet as conico said about my cost for a $4 2000v 0.47uf cap being over $30, yes, more like $34 or more now, is more than highway robbery. That does piss me off, not just for that component, but for all things now being imported into my country. Which takes most the fun, out of building things for me now, after a full three months of not being able to make a living. Did TK need to use complex nanopulsers, with delays, to achieve his first devices. Was he not surrounded by knowledgeable people, that would not just get faked out by some hidden means. Was Wesley faked out at Akula's house, as well.  I doubt it.  Yet, is Akula lighting his house with his device, now. I doubt that, also. Especially after the death of Adrian. Why else would someone want to kill him. Why the whole story is not being told, or known?
  I also think that Geo was or is very close to hitting on it. Time will tell... but, if he would only get back with us, one way or the other. I know that he is reading these posts, he told me so. My best wishes to him. May God, help him, and keep him safe.
   NickZ
AlienGrey
v8karlo
Nick,
It is insane to replicate someones work without even knowing what principle it uses to function properly.
Aldo, it is on schematic you use.
On transformer, primary 20 turns, secondary 40 turns we will got always double the voltage, halved the amps.
Can you get on this transformer same voltage and amps on secondary, no matter of number of turns?
You will say no!
Are you sure?
Supose we can.
Turn around windings.
Now the primary has 40 turns and secondary 20.
Primary will spend how much according to secondary?
And you still be geting same voltage and amps on secondary.
Is it possible?
The other thing is inductance related, it is also on your schematics which you use.
Invisible to you, because it is obvious too much.
If you zero the fields, what will happen to rest of the circuit?
Ask Chris.
He is on the right path.
The whole thing does not produce overunity.
Combined with second ingredient it forces source to spend very little.
That is why Chris is close.
It is like this:
Source is providing 100W. On secondary you got 80W (losses).
But then you force the source to spent only 5W, while you still got 80W on output.
It is inductance related.
You will never find it doing it your way.
Because, you all looking to get more on output using simple transformation of transformer, which can not give you more on u output.
Even superposition of HV will not help you, because it is simple transformation.
Transformers only transform, always with losses.
Superposition of fields only adds, always with losses.
It is on your scheme.
v8karlo
About Geofusion videos you are mentioning.
In AC circuit you place cap.
Cap is serial with source.
Reactive power is equal to power on cap provided by source.
In the end you spend nothing.
Same amount is returning to source.
Same goes for inductor.
So, cap or inductor does not spending anything in AC.
You can check this with any circuit sim.
Now, place a resistor (load) serialy with cap and source starts to spend power.
As the resistance is bigger, more power is spent.
If the resistance is zero, no power is spent (ideal circuit, but there are always some small losses).
Geofusion has serial cap and load.
By adding bulbs parallel, resistance is reduced dramaticaly, and source is spent less.
He is also showing this in his video.
So, he invented something old almost as I am.
Is it OU?
NO!
Just how reactive power behave.
Geofusion also concluded that superposition of HV does not bring OU,
and in video I watched he did not even use it.
But he was thriled by the fact that more lamps in parallel reduce consumption.
And reduced consumption happens because reactive power which cap provide in AC if there is no resistance in its way to source.
v8karlo
Chris,
I like this picture you posted so much.
It tells a 1000 words.
About Floyd Sweet magnets.
If the magnets interact with coils, there will be so much force between them.
And on pictures, magnets are wrapt with losse tape.
In magnet electric motors, magnets are usually nailed to chasis with screws,
so they can not move under strong forces.
Especially on forces which provides 5 or more kW.
So, magnets in Floyds device does not play any role at all.
But bucking or opposing fields does.
Why was vibrations present in Steven Marks devices?
What happens in bucking coils under few kW of power?
They repel creating strong vibrations and heat.
Of course, few litres of epoxy can sustain vibrations.
Yes, you are right on those things.
