0 Members and 150 Guests are viewing this topic.
NickZ
   conico and soliman:   Do either of you guys understand Russian?
   Here is the controllable Kacher circuit made by Stalker. I trust him over what Akula or Ruslan have shown, as they said that they would not disclose ALL. So, Stalker's circuits (below) were built and tested by itsu, and shown to work properly. The circuit provides for a multi pulse kacher, not just one firing at a time, but multiple packets firing each cycle.
   I have most all the needed parts to build the above three mosfet kacher circuit, but need some inspiration, or motivation to continue.   NickZ
NickZ
   Here's one of Geo's videos, showing a few tests that you may want to try yourselves, which results can be seen, even without needing the input to output measurements. However, the real test is once the feed back circuit is connected up to the input source. As that feed back loop and PS, will consume a lot of the output from the device, and change the previous tuning setting used, as well.   NickZ
   https://youtu.be/1weV296sjHU
AlienGrey
Quote from: soliman on June 23, 2020, 08:28:18 AM
hello everyone
AG, my point of view is that the voltage of the TC4420 pin 2 and pin 7 and 8 are similar and that the output voltage of tc4420 pin 7 and 8 depends on the width of the pulse.
Who controls the pulse width? Mainly C1 or C2 of the 74HC00. if you does not have enough pulse or pulse width the output voltage of the tc4420 will be very low and the katcher will not work. I have noticed that almost all controlled katchers are similar in their circuits and operations. I have built many circuits of different versions, most of them fail, because the pulse width is not high enough to produce the minimum voltage required by the Mos Fet to be activated.
No it does not work like that the 4422 to get a 1 out both inputs must be 1 if any are low you get a 0 none of this the catcher, oh it's not jno2w business.
conico
I do not speak Russian, I learned a few words on this forum.
today I finished a controllable katcher, I haven't tested it yet.
AlienGrey
Quote from: NickZ on June 23, 2020, 11:07:29 AM
Do you like building high power TX circuits ? I don't see a mic on the desk.  ;D ;D
