0 Members and 81 Guests are viewing this topic.
conico
what operating system do you have on your computer? Windows xp, or 7 or 10? install mega codec pack for your operating system and you will be able to watch any movie. It's free.
Void
Quote from: NickZ on June 25, 2020, 01:30:13 PM
   Speak for myself, is your answer. Well, I do speak for myself. You have a different view, well that is just great.
Variety is the spice of life.
   You really think that I have not been experimenting? I guess not. My 4000 thousand plus posts, videos, and tests, did not mean much to you, huh? I have not stopped experimenting, and never will. No need to tell me to "start experimenting". Even though for over a hundred years no one has shown you a working self runner, empirically,  and so you seam to have little faith of that possibility. Reality Check?   You say to me, "start experimenting", that's kinda rude. But, will you start experimenting? Makes no difference to me, not trying to get you into the ball game, unless you wanna play.
   What does anything I mentioned have to do with OU. Nothing, just saying what's on my mind. Nothing to do with reality.
Dang Nick.  :o  Does no one know what a smiley face means anymore?  ;D
You seem to be going more than a little off the deep end lately. Chill out amigo.
I was referring to your statement that 'we' don't want to get vaccinated. If by 'we'
you mean paranoid schizophrenics, then there may be a lot of truth to that. Vaccinations
are actually a good thing overall, which is easy for those who have a reasonable grip on reality to verify.
Many conspiracy theorists probably spend a fair amount of time in the pysche ward, and they fill 'social
media' with baseless conspiracy theories like that. Hopefully one of these days you'll get back
to actual experimenting again, instead of jumping all over everyone.  ;D
All the best...
NickZ
   Well, that seams to happen when someone calls me the "WE that you've just described. Then suggests that I should chill. Really!
   Sorry to you my friend. I didn't know that you wanted to get vaccinated. I should of known, that you were smiling, and what that means to you.
   Thanks for letting me know. You are right, I should not assume, anything about others...
Void
Quote from: conico on June 25, 2020, 04:36:27 PM
Hi Conico. I use VLC Media Player. Also free, and it can play pretty much any video format,
and you don't have to install any extra codecs. What do you think your 'dancing fish' waveforms indicate?
All the best...
conico
''Kind time of day. Maybe here we will find a common language. At once I will say that I do not sit at forums much. No time ! However, now for the 5th time I am collecting Akulin for a capacity increase. There are ideas ....
But in fact the people are looking for a bit of everything is not right.
All these systems operate on the basis of standing and traveling waves.
It is necessary first to catch the motion of particles in the coil. Those. as Kapanadze does with a tester or an ammeter.
Only at HF frequencies no ammeter will help and you will need to catch an oscilloscope.
   The first rule: Wind the coil 40 meters.
   2. Find out its resonant frequency (1/4 wave) Inductor 1/4 = 10 meters of the same wire (for example, 2.5mm) Connect the generator to a 10 meter coil, drive the rectangles at a frequency of 1 MHz and crawl higher until 40 meters do not appear sinusoid. The maximum amplitude. The generator is desirable to take a normal, laboratory! With output adjustment from 0 to 20 volts. We achieve maximum amplitude and move tenths of a kilohertz until it starts to dance. This is your wave resonance !!! We fix the frequency and voltage. It is for this all have to do the generators.
Further ... Tesla we shake under this frequency that the effect has turned out. Then we do everything as I did or the Shark. In this case, everyone wants to repeat this device. Forward! We fix everything beautifully and stiffly, without forgetting that the resonance and effect can escape in the case of fastenings on the snot. We need to get the effect itself and work, and not a ready device.
Once you begin to understand what to do next, you can already move. So .... Tesla, as we know, also wets the sinusoid. Suppose your frequency is 1.821MHz. The frequency, but alas. It is necessary to adjust Tesla on it. The shark used a critic between Tesla and the toroid (Antenna) over the inductor. This is just an accurate adjustment. It is needed before launching. Then the system holds and no matter what has slipped in not large limits. But! Again ... What where? On the Inductor we feed the signal of rectangles with a frequency of 1/50. Consider: 1820: 50 = 36.4 kHz pumping a rectangle through the junction (Pot) with 23-29 turns of wire 2.5 squares.
I repeat, you need to make the voltage on this harmonic not 10-20 volts, but higher by an order of magnitude. Approximately up to 50-60 volts and get the same dancing effect at the output. Further ! Do not forget that Tesla does not need strong power. Do not let sparks run and wet so that it breaks through. This is not necessary !!! It's better to make a controlled Tesla. Continue: The output voltage will be 195-200 volts. This voltage will not be higher. Why? Later we will return to this. It is necessary to rewind the transformer-reactor (Coil) so as to obtain the desired voltage. This requires experiments. Remember that we push the current in the reactor with a transverse wave. Created by Tesla. In the coil another wave is formed under the action of pumping by rectangles. The particles of which constantly rotate left and right. By giving them the movement of the pulsating Tesla, we disperse them in the very conductor. This is a gemmoroid understanding, but a fact. Tesla must operate in one half-cycle or one arm of the transistor. It is advisable to manage the Tesla pack - pulse generator. When everything is clearly adjusted, you will see how the effect manifests when changing the width of the pack. Consumption Tesla is scanty, and pumping does not strain at all.
The current at the output is up to 7 amperes and the voltage is 200-209 volts. Bulbs and PSU pulses work well. Now for removal:
   1. The coil is connected via a diode bridge. No parallel capacitors !!!
   2. You need from Tesla only one half wave. Otherwise Tesla will take what she gave, back !!! Therefore, and put the diode from the ground to the very take-off coil (40m) The shark did this at the reception. He removed one part of the sine at the reception itself. Because Tesla. No one knows this and -bip-tsya to this day, nichrome does not work. It's clear! You need to swing the swing in the coil of energy removal.
It is there that we push the current. By the way, the surplus from Tesla and the frequency setting of the Shark used a simple light bulb. Since the Inductor is galvanically isolated from the entire circuit, the light bulb serves as a resistive load to suppress surplus from cords and pickups. You can not bet, but do not rock Tesla very much. Do not ! Remember that the current is subject to voltage. This I see from experiments that I spent 2 more years ago. Next: The diode on the receiving take-off coil destroys one half-cycle and so we swing the oscillations without hindering them by the negative Tesla period. This, too, many do not know and continue to sculpt. That's why Roman (Shark) says that he is eating ground ... Everything is right!
Because it kills the half-period pulse at the reception, which is grounded. This can be seen in all his settings! I wondered for a long time why he decided to use this solution and realized that it's easier to pick up BB diodes. Since interference at such frequencies in Tesla will lead to its improper operation. In other words, it will not be possible to cut off the half-period. Kapa solved this issue with an arrester and rectifiers at low frequencies. There everything is simpler, but more wires .... So on the German installation the diode is small, Tesla is far away, the grounding cable is long. By the way is equal to the length of Tesla !!! Do not forget about grounding .... On this installation it is important and without good support (grounding) will not work. Do not forget that the systems use high voltage. As we know, it moves even in the air. That's why grounding is necessary. Plus wave resonance and safety .... Like that .....
Ref: Ruslan K
Connect this information to this Video and Translation:
https://youtu.be/_GO2ADSPbK0  ''
I tried to use my function generator and I understood that Mr. Ruslan does not say everything. It is frustrating.
I used the function generator (FG) just like in Ruslan's video and, nothing, no dancing wave. I took down the inductor and used only coil grenades, the same result without dancing waves.
I remembered that push-pull does not reach 50% duty-cycle only 45%. I changed the duty-cycle in FG to 30-20-40% and the dancing wave appeared. Did Mr. Ruslan forget to talk about Duty-cycle?
Of course, Ruslan forgot to tell us what capacitor he used in parallel on the grenade coil. I saw in his video two Wima 470nF capacitors in series maybe. if you change their value everything changes.
No result for me with my function generator that amplifies the signal up to 20v but for square wave only up to 15v.
I didn't understand why he didn't use Push-pull which gives a square signal and is much stronger than FG?
Now I use push-pull as a generator but the oscilloscope doesn't show me the same signals as Ruslan.
I rewound the inductor, it is indistinguishable with or without inductor.
A lot of work and without the desired result, is frustrating.
