0 Members and 100 Guests are viewing this topic.
conico
Ok AG.
You can have the same katcher but with 7414 or 74HC14 that works at more than 2Mhz and no TL494.
I chose TL494 because it has a bigger out put.
AlienGrey
Conaco. thanks for the circuit I will have a look at it. It has to be triggerable, In sync.  :o
Re the TL494 the only problem with that, that is' how they stack trigger sync them, then it would make life easier.
See circuit that does that. 'With modulation input'! then it will be of use.
If you watch TK's video in the garden when he is in the back room he says he solved the sync stability problem.
all the circuits suffer from this problem. Y need to scope his device to see how his works, is it an energy spike
or a pulse packet ? Who knows? 500khz or 1.6 Mhz same thing
AG
conico
My Katcher with TL494. Test for frequency.
1.695Mhz.
AlienGrey
Quote from: conico on July 03, 2020, 03:30:12 AM
1.695Mhz.
Conaco,
Yes! on your test TL494 try hooking up your Signal generator to the TL 494 via a cap
and posably a posative going diode to pin for and see if you can trigger it !
rather than it free running.
I just tried this my self the problem is it needs to be driven by a syc pulse witch makes it complicated or it
screws up the pulse width mechanisum.
conico
In katcher diagram, TL494 is free running. The signal from him he will combine with the signal from Push-pull in 74HC00 nand gate.
the signal from the generator is positive and negative and the signals from TL and the one from Push-pull are only positive, Katcher will not work as it was thought. You must take just pozitiv part from signal generator, no more then 5V.
Or you may need to change C1 from 2.2nF to 4.7nF or C2 making biger.
Sorry i'm at job now.
