joaouchoa and 449 Guests are viewing this topic.
r2fpl
All connections to water pipe !?!? why ?
GeoFusion
The greater ground the better connection and attraction for good output.
The less ground in my experience is less power out.
In comparison with the signals sharing from the TL494 in shown diagram,
where on my setup it is shared after the amplifier which is the 1R2110 to the kacher circuit.
Busy replacing small caps on the Pushpull driver, TL494 was limited till 27Khz.
Now will be able to have the range of till 50Khz which is necessary, maybe this was limiting me
Since very beginning.
Cheers
AlienGrey
Quote from: GeoFusion on July 05, 2020, 02:46:38 PM
Cheers
Geo it's been a long time, one thing I wanted to ask you Are you still running your katcher at 1.7mhz
only that's quite a high frequency as most of the circuits and drivers coming out now are around 300- 400 kHz?
if you go below into the 200khz the wave form tends to get distorted ( perhaps 750 ish kHz appears optimum, witch is above the 494's capability) with poor transfer from the spaced driver
coil which is just an ordinary Tesla coil, nothing special.
AG
GeoFusion
Quote from: AlienGrey on July 05, 2020, 03:54:24 PM
AG
Yes it has AG, to busy with life and other human alike experiences.
1.7mhz is one of the values depending on my tapping point ( lenght ) of the secondary Tesla I tune too.
I had good results back then around 800Khz - 1Mhz ~ range on the tesla when Pushpull circuit was driving around 16Khz-18Khz.
All depends where the standing waves are good and the resonance to set too.
Just make sure your push-pull driver AKA TL494 chip set can drive up till 50Khz range, It is important and will be sufficient for @ 40 meters
grenade coil receiver. All  HV caps connected between yoke and grenade and grenade output are all in series for tuning...after that
the HF HV FWBR to caps that will be charged in Parallel, this is what I am about to go thru as approach. did it once before on outside bench
but on a different approach, some variant of Ruslan back then, Video is on my channel. Don't forget the ground, it cannot operate well
without it.... Well this design then... because there is one that does not need ground and utilizes 2 antennas with double HV coils with
centertap. ;) that will be next after we finish this.
seychelles
Hi R2FPL the reason for very good earth is because the whole concept of this invention is
to extract charge from an asymmetric supercapacitor. The idea behind this is to use the
STANDING WAVE THEORY to bring the charge into the grenade so that the electrical charge can be
extracted. SWR  is a standing wave ratio. Very likely one can use a CB radio to do the same
job but at a 27 MHz resonance. but again the EARTHING has to be super good. To test for a good
earth is to connect 240v AC TO a lamp of 100 watts  IN SERIES WITH YOUR EARTHING SYSTEM
and get the best current reading. THICK COPPER WIRE AND MANY COPPER TUBES IN THE EARTH.
