0 Members and 219 Guests are viewing this topic.
Thaelin
d3x0r
Self-force and radiation reaction in general relativity
https://en.wikipedia.org/wiki/Photon_sphere#Photon_orbits_around_a_Kerr_black_hole
some projection using the specified math...  [/size]https://www.youtube.com/watch?v=HQZDvrNds1A kind of a poor quality render at that...
Attached image generated from https://d3x0r.github.io/STFRPhysics/3d/index4.html as a toroial ... well here *sets octave 0 takes another picture* a mobial toroid winding hopf fibration projection... which is ... just the image of a rotation in rotation coordinates, not even really 3d space, and although it shows the individual frames, all of that would apply to just the curvature of a single point...   It's a axis-angle rotation that is stepped around a fixed axis and then stepped around a variable axis (I could just make the fixed axis be flexible and provide more relative freedom, but... I didn't, so there's basically a rotation rotated by a rotation and then showing the rotations that all have the same axis of rotation in linked circle....
Really what's attached are just pretty pictures; and yet they resemble so many other things, I am somehow failing to make a real connection there...
The last two pictures are example pictures from the first article about stable quantum spin orbits...
d3x0r
 :) and these explode really neat too at overflow of spin conditions
(the sliders are at a range of like +1 of 'within range')
... so matter into energy?  Again this is just the coordinates of the angle-angle-angle of rotation... or sort of the axis of rotation scaled by the angle of rotation... and mostly not related to anything in space... it's really just  the properties of a single point in space (and all points associated in it's local frame aka rigid/soft body)
partzman
Quote from: Jeg on July 26, 2020, 05:56:28 AM
AG
It is a russian guy here
https://www.youtube.com/watch?v=0bBTqA6opUY&list=LL_HNW6MviMNNhdWRBtG5i3w&index=33&t=0s
Question to him: ......Thank you  for sharing. At 10:17 there this high frequency waveform. On which point inside the circuit we look for this?...
Answer:
Высокочастотный сигнал генерит ТЛ494. Паузы между ними делают усилители ошибки по параметру степени насыщения феррита. По сути тут два генератора первый на внутреннем генераторе 494, а второй параметрический зависящей от силы тока протекающего через L1 снимаемый на шунте R1.
Using Google translate-
"The high-frequency signal is generated by TL494. The pauses between them make the amplifiers errors in the parameter of the degree of ferrite saturation. In fact, there are two generators, the first on the internal generator 494, and the second parametric depending on the strength of the current flowing through L1, removed on the shunt R1."
Pm
color
Format Kostyana :
If the Korean language passes the Google Translator, the placenta is often translated differently from my intention.
The operational amplifier is a Google translator error.
TC4451
https://pdf1.alldatasheet.co.kr/datasheet-pdf/view/195330/MICROCHIP/TC4451.html
