0 Members and 88 Guests are viewing this topic.
justawatt
https://mazeto.net/index.php/topic,9829.0.html?PHPSESSID=jtvbljh3ad9aihl3n0597p3gt0
this guys circuit is so cool it will automatically adjust to resonance frequency of the coil.
his message
" Some time ago I wanted to sell my Tu-Tu generator, but apparently no one wants to buy it, so I will give it to you as a gift. I am attaching a file with the scheme. In essence, this generator is a four-terminal with two composite thyristors made with 4 transistors. The supply DC voltage is connected to two of the four terminals of this four-terminal, and a series LC group is connected to its other two terminals, marked with the letters A and B. Thus, the coil and the capacitor are powered at their own resonant frequency. Even if the coil has a movable core and changes its inductance, the resonance is still maintained automatically. Different capacitors can also be included, so the frequency will change abruptly, but the resonance will again be self-sustaining. I put big electrolytic capacitors next to the power supply, and at points A and B I connect a coil and a capacitor in series, in which the resonance takes place. I have used the transistors A1294 and C5200. The diodes in the "thyristors" are Schottky.
   I guess the circuit can work if only a coil is connected in points A and B, and instead of electrolytic capacitors small non-polar ones are placed. The transistors have to hold only the supply voltage while in the resonance the voltage is very high - I have reached 3000 volts. My transistors are for audio frequencies and above a certain frequency they start to glow, but otherwise they work very well. Let the electronics specialists put some high-frequency transistors and see how the circuit will work then. The advantage of my Tu-Tu generator is that it has no complicated control and is very reliable, stable and always resonates no matter what coils and capacitors we put on it. The disadvantage is that the current passes through two transistors and from there we have greater heat loss.
n. n. The name Tu-Tu comes from the fact that the current moves "tu" to the left "tu" to the right."
color
5 KW nominal lamp consume !
How much these DC 220 V and 2,35-2,65 A reach this nominal value ?
100% duty cycle or works the coils arrangement also as duty cycle divider ( besides frequency and voltage divider potential) ?
When I blow the nominal value of the Kapanase generator to me, I cannot answer.
I only guess the generator made by Kapanase.
My guess is that the placenta is based on experiments.
Kapanase uses 110/220V for the generator because it is advantageous for operating a 5KW bulb.
It is also because it is a universal power source they use.
NickZ
Nobody has built a working Kapanadze replication, not even the Russians. Are you assuming to know what he has inside of the tin can??? I can tell you, but, it won't help. So, keep guessing... as there is no schematic, or full instructions to his devices.
   The reason that this thread was started was to work and discuss the Dally, Akula, Ruslan type of devices. Which do have diagrams, and all, even though there may be something not shown, hidden, or missing.
   The Kapanadze thread is where to place your ideas about TK's systems.
   Thanks again,
    NickZ
The only difference between the Kapanase generator and the Ruslan generator is the difference between the Tesla coil operation and the yoke-transformer.
So, free generator users who work outside of this cafe try to find a resonance method and make a generator in almost the same way.
And they don't say they figured out how to resonate.
We are used to reading leading in the experiments and languages ​​they show.
NickZ only wants the correct schematic.
However, no one discloses the exact circuit diagram.
color
https://www.youtube.com/watch?v=NTJooI5TKms
Their complaints are the same.
Why not?
I will ask them in reverse.
How much do you understand resonance?
Is my question wrong?
d3x0r
